daves16v 1 Posted April 2, 2008 Does anyone have any photos of how the rear seat hump is attached? Recently acquired full leathers for my valver so don't have the fixings for it. Front and back fixings would be good. Many thanks. Dave Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 2, 2008 Hiya - it's just 4 x M6 Machine screws to hold the hinge to the bracket with the plastic tunnel in between acting as a washer... The problem I think you have if it's a late 16V is that you don't have the chassis bracket on the car so you may need to weld / fab something up... Quote Share this post Link to post Share on other sites
Toad 0 Posted April 2, 2008 I can cut a bracket out of my breaker if you want. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 2, 2008 Thanks guys but I work in fabrication so should be able to knock something up. Toad, I'll give you a shout if I need your bracket. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 2, 2008 How does the rear 'click' into place? Quote Share this post Link to post Share on other sites
Toad 0 Posted April 2, 2008 I'll try to get some pics of mine tomorrow if it helps? Quote Share this post Link to post Share on other sites
Toad 0 Posted April 2, 2008 How does the rear 'click' into place? The rear of the hump? There's a plastic clip on the floor which grips a bar on the base of the hump iirc I'll look at mine tomorrow and wack pictures up as necessary. I added you on messenger too. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 2, 2008 How does the rear 'click' into place? The rear of the hump? There's a plastic clip on the floor which grips a bar on the base of the hump iirc I'll look at mine tomorrow and wack pictures up as necessary. I added you on messenger too. Cheers matey. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 3, 2008 Thanks Toad :D Quote Share this post Link to post Share on other sites
Toad 0 Posted April 3, 2008 No worries, sorry they're a bit blurry... I'll try to get some from the bracket fitted to my scrap shellso you can see the fitting better. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 3, 2008 No worries, sorry they're a bit blurry... I'll try to get some from the bracket fitted to my scrap shellso you can see the fitting better. You're too kind. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 12, 2008 Front bracket now fabbed and on! Quote Share this post Link to post Share on other sites
easypops 8 Posted April 13, 2009 Front bracket now fabbed and on! You didn't happen to make a spare one of these did you dave? :D Martin Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 13, 2009 Front bracket now fabbed and on! You didn't happen to make a spare one of these did you dave? :D Martin Martin, I'm afraid not mate but I can probably make another if you like. Let me know. Dave Quote Share this post Link to post Share on other sites
