boost monkey 0 Posted April 17, 2008 It's in my project thread...give me a mo... Looks like a single skin to me, but it's a few mm thick IIRC: Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 17, 2008 Thanks monkey, For easier installation I'm going to go for self tappers but I'll need to do some tryouts so these won't be ready till next week. Thanks Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 17, 2008 I've just got back in from trying out different self tappers, the bad news is the Corrado floor is just too thick for self tappers, the threads just strip no matter what whole size I drill or what screw size I use. So it's back to Tapping the hole I'm afraid. I'll look into the costs of supplying the correct drill bit and Tap for the job. Quote Share this post Link to post Share on other sites
easypops 8 Posted April 17, 2008 I've just got back in from trying out different self tappers, the bad news is the Corrado floor is just too thick for self tappers, the threads just strip no matter what whole size I drill or what screw size I use. So it's back to Tapping the hole I'm afraid. I'll look into the costs of supplying the correct drill bit and Tap for the job. Good stuff mate, I'll have a set anyway :D Quote Share this post Link to post Share on other sites
Traverse 0 Posted April 17, 2008 Good fix. I'll probably try and rig one of these up when I go home from school for the summer. Quote Share this post Link to post Share on other sites
Jay2 0 Posted April 19, 2008 Anyone got a pic of what a C looks like without the plastic tunnel covers? :( Thinking of just getting rid of mine altogether after constant probs with it, I've got a large leather handbrake gaitor to cover up all the handle gubbins, but what other horrors is it hiding? Cheers. Quote Share this post Link to post Share on other sites
Toad 0 Posted April 19, 2008 The carpet is cut down the middle, there's wiring and the hanbbrake mech, the back of the gear lever surround will be a large hole etc. I did roll in this style for a bit because I was lazy. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 19, 2008 That's how ron rolls now. Plastic trim is for primos. Quote Share this post Link to post Share on other sites
swginn 0 Posted April 28, 2008 I'll take a set definitely, just went to the hassle of refitting mine there yesterday and it's after coming loose already. Can you PM me the amount payable for the kit with the appropriate drill bit and tap please Dave. Delivered to Ireland of course. Cheers. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 29, 2008 Bear with me on this, I will hopefully have the kit ready at the weekend. Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted May 8, 2008 Bear with me on this, I will hopefully have the kit ready at the weekend. Any news on this Dave ? Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 8, 2008 Ok, made some small changes and they're now ready. I will have to write a small install guide but that won't take long. Price posted is - £12 if you DON'T need the appropriate drill bit and Tap. £16 if you DO need the drill bit & TAP. PM me if you want a kit. Thanks Dave Quote Share this post Link to post Share on other sites
VR6 South 0 Posted May 24, 2008 Mine arrived this morning. Thanks Dave. Well engineered I must say :D. I can't fit it though as the C has a flat battery and is stuck in the garage :( Quote Share this post Link to post Share on other sites
the delta force 0 Posted May 24, 2008 Received mine y'day, will have a go at fitting it tomorrow.... Thank you. :D Quote Share this post Link to post Share on other sites
the delta force 0 Posted May 30, 2008 Bracket fitted and it holds perfectly.... One less rattle to worry about. Great idea, Thanks Dave. Stefan Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 30, 2008 That's the baby :clap: Quote Share this post Link to post Share on other sites
MonkeyVR6 0 Posted August 30, 2008 Are these still being made? I could do with one, with the drill bit and tap thingie please!!! Quote Share this post Link to post Share on other sites
webbie 0 Posted August 30, 2008 just watch the handbrake bolts aren't coming loose or ripping the metal where it bolts on like mine did, the movment in the hand brake kept knocking it off it's clip and dodgy plastic nut type things. had that fixed and now the middle stays down with no probs. Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 30, 2008 Are these still being made? I could do with one, with the drill bit and tap thingie please!!! Yes, PM sent. Quote Share this post Link to post Share on other sites
ebby 0 Posted September 4, 2008 i'm interested in one of these please, need both the tap and drill bit also...cheers Quote Share this post Link to post Share on other sites
t_chet2001 0 Posted September 24, 2008 I would definitly be interested in this, mines bloody annoying me, are they still being made? PM me and we can sort it out Quote Share this post Link to post Share on other sites
MonkeyVR6 0 Posted September 25, 2008 Sorry for the late reply, no photos as my internet at home is down... Anyway, the kit itself came quickly and included all the drill bits, tap, and screws etc that I required. The instructions were fairly easy to follow, even for a techincal dumbass like myself. The most annoying part was using a phillips screwdriver to seperate the two bits of large plastic that comprises the handbrake cover from the gearstick to the rear seats! Now I've got the brakcet on, it doesn't budge/squeak at all, as it probably did when it was new! A good, quickish fix and fairly cheap kit as well. Recommended. Quote Share this post Link to post Share on other sites
Dogzyboy 0 Posted September 25, 2008 I wouldn't mind one of these if they are still available? It's got to be a much better solution to the piece of string I currently have holding the plastic in place!! :) Drop me a PM if you have any left? Cheers. Doug edit: I'll require the whole kit if possible? Cheers. Quote Share this post Link to post Share on other sites
