fla 9 Posted May 30, 2008 Could anyone tell me the the colours of the two wires going to the black temp sender in the thermo housing (you'll know if you've got aircon). I've got two connectors loose, dont know which one goes there :? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 30, 2008 argh, did you ask me for photos, i must have forgot, i can go and get you some in a minute Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 30, 2008 :( just been out to get pics, but can't get to see the connectors as they all covered up with a plastic thing that i can't seem to get off now. also just noticed my water level is 1cm below the min line on header tank :mad2: :bad-words: i hope nothing is about to break :sad: Quote Share this post Link to post Share on other sites
fla 9 Posted May 30, 2008 argh, did you ask me for photos, i must have forgot, i can go and get you some in a minute No worries 3c. Better get checking for leaks if the level is low.. Quote Share this post Link to post Share on other sites
Toad 0 Posted May 30, 2008 I assume that you have a black conector from the wiring loom with the two other temp sensors, and a black connector from the wiring loom by the starter motor? The one from the starter motor goes to the black temp sensor, and the one from the loom with the other temp sensors goes to your inlet air temp sensor in the inlet manifold. Quote Share this post Link to post Share on other sites
fla 9 Posted June 2, 2008 Toad, I'll have another check which connectors are where and post some pics - tbh over the weekend i was struggling to reposition the engine (just 2cm adrift :mad2: ) All done now just need to refit everything else. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 2, 2008 If anyone needs this switch / sender I appear to have ordered the wrong one for mine and have a VR/Aircon black 2-pin sender available Quote Share this post Link to post Share on other sites
