dirtytorque
DirtyTorque's G60*Now with 8 more valves*
Anyway what are peoples views on say using internal or external wastegates.
I have read that internal ones are better suited for larger boost applications.
An external wastegate is going to be cramping at the back of the bay though I would have thought especially as I have ABS?!??
Or am I talking pooh???
ta
Robert.
Stick the word turbo in your title you should get more input then. :brickwall:
ta
Robert.
He talks sense :wink:
*Blows dust of thread*
Wow check out all the turbo talk above.
I didn't go that way in the end decided to stick with the charger.
I am in the process of finishing off my 2.0 16v g60.
It s running megasquirt 2 extra and is using a distributorless setup,incorporating a 32-1 trigger wheel.
Just updating my thread for posterity.
soon with any luck.Just need a pas pump really b4 I can take it for a spin. :)
Oooo! get you!!
:) Really good to see it going. :) Can you bring it down on the 30th? :)
Really am hoping to.
Tbh I just want to get ina drive it now.It sounds really promising.
I havn't driven my corrado since november.
I know how you feel Rob! Well done for getting it sorted - no way in hell could I wire up MS!
what are you doing for intercooling? I'm guessing the black cooler is for oil?
Hi Jon.
It really isn't that hard to wire up MS to an old car like this.It has quite simple electronics and you can just make use of things that are already there.Just a bit of a pain removing break servo etc to run in the wires.
In terms of splicing into the stock loom you just need to get access switched 12 volts and then the fuel pump.
Yeah the black radiator in the stock intercooler position is my mocal.
You can just make out my pro-alloy fmic infront of the radiator.Same one Yan has on his car I believe.
Can't wait for the thing to become a car again,and not just an expensive garage sculpture.
Should be about done playing around with the engine now.
Just have to configure the megasquirt properly now which will involve lots of driving. :)
About bloody time.Nice to have a car again and not just a mixture of parts in a garage.
amazing work there!
I agree that paved garage is just sublime.
Beat me to it! :ignore:
Do me a favour Rob, get me some pictures of the pipes from the supercharger to the intercooler please and also what size are they?
If i had 1 constructive criticism is the top rad hose, can you get that a little neater with a different shaped one.
yeah it I hear you but it is perfectly functional.just got back from over an hours drive which included all types of driving and no coolant temp dramas so coolant is circulating.
There are alot of things i want to do in that general area.
a boost return for one and also a engine breather into the intake system via a catch tank.
My main concern at the mo though is a reasonable level of driveability and lambda control for the MOT which is due soon.
My supercharger to intercooler pipework is horrible.Just made of of multiple sections of stuff I had lying around.I was loathed to spend too much money until i saw that it worked.
So now i can refine it a bit.Actually it is stuff you probably already had at some point because I think you had a pro-alloy (jabba sport )fmic did you not?
Thanks for the interest and comments.
I drove it for the first time last week actually abd it was a horrible experince.I was rushing because I wanted to take it to stonor park and it just wasn't ready.Megasquirt wasn't setup right and I had a faulty radiator and the temps were creeping up.
Have had a week to iron these things out and today was the most enjoyable drive I have had in thus far.Nearly normal driving.Still needs alot of work on the map side of things but I'd be happy to make a longish journeys in it now.
Hopefully it is going in the right direction.
glad to see its up and running, take it the pas pump was ok...
yeah steering is working fine.
thnks again mate.
Hows the squash coming along?
thnks again mate.
good stuff buddy, would love to see this in the metal...
squash is all good though i havnt played this week as ive been lazy, though i keep spending money on rackets that i dont really need lol...
