Jim Bowen 1 Posted June 18, 2008 not long ago i fitted a new rad, crack pipe, thermo housing, a set of samcos and a few other bits to the car (vr6) been driving it sicne and all seems fine, but have noticed the coolant level going down very slowly, its taken a few hundred miles to lose about 1cm in the header tank. i can't see any signs of anything leaking, not sure where to check, what would be the obvious places, the trouble is thats its such a small amount there aren't any signs of a leak :( :( Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 18, 2008 Replaced the header tank cap? Quote Share this post Link to post Share on other sites
fla 9 Posted June 18, 2008 How have teh temps been? It could be some trapped air slowly making its way out. Top it up and check it again after a few hundred miles. Also, see if you can have a peak under the car after a run if you suspect any other leakage. Run the engine with teh car stationary until the speed 1 fan trips in and watch the level in the tank, whilst inspecting the cooling circuit. Quote Share this post Link to post Share on other sites
NottsCounty 0 Posted June 18, 2008 Heater Matrix on it's way out? Pretty hard to check for, unless the front windscreen is getting steamed up?? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 18, 2008 all the running temps have been fine, the heater matrix has been replaced once already by the previous owner and i have a new header tank cap, blue one. guess i'll just have to run it as suggested and check everything, i did think i was quite lucky to change it all and not have anything leak :lol: Quote Share this post Link to post Share on other sites
JMC 0 Posted June 18, 2008 not long ago i fitted a new rad, crack pipe, thermo housing, a set of samcos and a few other bits to the car (vr6) been driving it sicne and all seems fine, but have noticed the coolant level going down very slowly, its taken a few hundred miles to lose about 1cm in the header tank. i can't see any signs of anything leaking, not sure where to check, what would be the obvious places, the trouble is thats its such a small amount there aren't any signs of a leak :( :( My G60 does that. It seems as though there is a slight leak where the coolant pipe goes into the block - corroded flange or something like that. Basically I have to top up the coolant every few hundred miles, until I get round to changing the flange. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 18, 2008 can't you buy metal flanges or something? They ring bells... :scratch: Quote Share this post Link to post Share on other sites
craigowl 0 Posted June 19, 2008 Wouldn't think so - is it not just a hole in the engine block? I had an irritating slight leak at that point where my new Gruvenparts pipe went in. I have now repaired it. The O ring appeared to have a little damage after forcing the pipe in dry. Best to lube it up with something :camp: Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted June 19, 2008 Get a compression test to rule out the head gaskett. Quote Share this post Link to post Share on other sites
