junkie 0 Posted July 17, 2008 Right then in what order do things need to come off so i can remove the engine and gearbox and are there any specialist tools i will need to do so. Im talking the drvetrain elements of the car. Quote Share this post Link to post Share on other sites
Toad 0 Posted July 18, 2008 Driveshafts, gear linkage, speedo cable, clutch cylinder-either cylinder from gearbox or solid line from cylinder. Driveshafts use a spline bit (I think you have bought one?) Couple of bolts for gear linkage, and electrical plug for speedo. Quote Share this post Link to post Share on other sites
Rob_B 0 Posted July 24, 2008 its an m8 spline bit for the driveshafts if i recall. just remember t8o tap them in a bit as they will be full of crap and you really dont want to round them off! no other special tools required the worst part about removing the g60 is the exhaust, its a real biatch to remove. once you get that unbolted, the front end out, engine mounts undone, clutch slave disconnected, wiring removed, shifter cables disconnected then you can jack the engine and box up and pull out the front! its easy when you get into it. ive taken one out in 2 hours! :shock: Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 25, 2008 Gimee a shout if you need help with lifting :camp: ?? & stuff Simon.... Quote Share this post Link to post Share on other sites
