steveo29
g60..how does the charger return fit to block?
front of the engine block seems to getting damp with oil...i recon its coming from the charger oil return
how does this fit to the block?
Banjo bolt with 3 washer type seals - not very clear on ETKA
Worth buying a few new washers from VAG mate - some are steel and some are copper
do you have the original charger silencer outlet? when my charger was knackered (leaking oil)it would force oil out of the silencer box.
nah mine has the u bend ..its on a golf
the block is damp under the dizzy and up to the gearbox, no biggie at the minute but if i can nip up a jubille or something i will
The return just pushes onto the block and has a crimp type jubilie clip. It fits just above the sump.
