-Neil- 0 Posted September 1, 2008 is this correct, anything else i should know... Bottom ball joint Track rod end / steering ball joint Brake caliper Drive shaft nut Two strut bolts what do i do about the ABS or anything? Quote Share this post Link to post Share on other sites
was8v 0 Posted September 2, 2008 ABS just plugs into sensor on hub knuckle. Just unplug. If your driveshaft has never been removed before, VW put some kind of uber powerful loctite on the splines so you may need a puller to get the hub off the driveshaft. Dont bash it with a lump hammer and drift as it can distort the end. Quote Share this post Link to post Share on other sites
herisites 0 Posted September 2, 2008 If your driveshaft has never been removed before, VW put some kind of uber powerful loctite on the splines so you may need a puller to get the hub off the driveshaft. Dont bash it with a lump hammer and drift as it can distort the end. Been there before :brickwall: Can be done if not tooooo seized in if you use something in the center to hit rather than just whacking the splines which will just distort. Quote Share this post Link to post Share on other sites
was8v 0 Posted September 2, 2008 Can be done if not tooooo seized in if you use something in the center to hit rather than just whacking the splines which will just distort. Yeah, I bashed 7 shades out of mine with a lump hammer and drift being veruy careful not to go near the edges/threads. It eventually came out, but the end of the shaft had "belled" out, I had cold-forged the end of it into a different shape so I couldn't get the nut back on on re-assembly. Had to tickle it with the grinder and use a thread file to get it back on. The moral of the story is to use a puller if its not moving after a few taps. Quote Share this post Link to post Share on other sites
