boost monkey 0 Posted September 8, 2008 Hi team, trying to fit my boge turbos, and the top brass plates (what's THE name for these? I can never remember) on the car currently have a dished section which is too narrow to get my 22mm drop-ring spanner into. Any suggestions? Toad has filed flats into his socket to overcome this problem (i.e. being able to use a 6/7mm allen key to stop the damper rotating with the top nut) but if someone knows where I can get a more acute angle drop ring spanner, or a 22mm socket with external flats I would be greatly appreciative. Thanks :grin: Quote Share this post Link to post Share on other sites
Lizard Racing 0 Posted September 8, 2008 Dont the spark plug sockets fit or am I being dumb? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 8, 2008 ah yes they do buddy, but I need a hole in the top to get the allen key in aswell! Quote Share this post Link to post Share on other sites
G60_edge 0 Posted September 8, 2008 I just ground the external diameter of the ring spanner down until it fitted in the recess. Worked a treat. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted September 8, 2008 I used a normal socket and a pair of mole grips to turn it. Worked a treat also. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 8, 2008 I got a deepset spanner from my local auto tool shop. Then used a 7mm allen key with a handle, you can fit a bar over the handle if you need to also. Quote Share this post Link to post Share on other sites
Kempy 0 Posted September 8, 2008 Try a diesel injector socket/oxygen sensor socket, I got one of these, from laser hand tools http://www.motorshack.com/acatalog/Special_Sockets.html halfords do them I think Quote Share this post Link to post Share on other sites
Philuk 0 Posted September 8, 2008 get some dog leg spanners, they did the trick for me! :D draper do a full set, they called deep offset spanners Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 8, 2008 i have a dropped head spanner, but the arm is 45degrees between head and bar and it catches on the cup section of the mount before I can get it over the 22mm nut. I will have a look at those spanners though! Cheers for the help. Quote Share this post Link to post Share on other sites
coolrado 0 Posted September 9, 2008 most spark plug sockets have an external hex drive at the top, so all you should need is a spark plug socket, a spanner to fit it, and a long allen key to poke down through the hole that you would normally use for the ratchet, halfords do a long allen key with a chunky handle which is ideal for the job. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 9, 2008 yeah I have a 7mm Sykes-Pickavant allen key which is about 6" long on both sides of the 'L', but the new dampers have a 6mm female allen in the top! Why is it never easy? Quote Share this post Link to post Share on other sites
G60_edge 0 Posted September 9, 2008 If you are really struggling, I could probably get my 'custom ring spanner' to you. A friend of mine works with your brother. Quote Share this post Link to post Share on other sites
horney 0 Posted September 9, 2008 I use a long socket, allen key and stilsons (sp) as they tighten their grip on the socket the more you force them to undo. Also always worth adding the McPherson strut tools for the slotted nut to your tool kit. I used to tap the slotted nut round with a hammer and scredriver but using the correct tool you can get it so much tighter! nick Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 9, 2008 yeah i'm not sure why my top plates are so gay. On an old audi of the same era we could easily get the ring spanner on with a bit of scaffold on the end and it was easy peasy! my plates seem really narrow :/ Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 9, 2008 If you are really struggling, I could probably get my 'custom ring spanner' to you. A friend of mine works with your brother. :notworthy: :notworthy: :notworthy: that would be awesome. Andrew has just jetted off to Amsterdam for a week on business, but I prob won't try this until next week sometime anyways. Is your friend called Graham and does he have 3 Audis? I hear he's a good guy. Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted September 9, 2008 the ones on my VR were seized solid, tried everything to remove them, ended up angle grinding around the centre nut and removing them that way.... Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 9, 2008 good idea mate, i've found some replacement top plates now so i don't mind cutting these ones up. bit annoyed they changed the allen key inset from 7mm to 6mm now though. Argh. Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted September 9, 2008 yeah just do it, but be careful not not cut into the actual bodywork!! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 9, 2008 ah yeah, good call :nuts: If I do it'll prob be with a dremel, so less margin for destroying suspension turrets! Quote Share this post Link to post Share on other sites
G60_edge 0 Posted September 9, 2008 If you are really struggling, I could probably get my 'custom ring spanner' to you. A friend of mine works with your brother. :notworthy: :notworthy: :notworthy: that would be awesome. Andrew has just jetted off to Amsterdam for a week on business, but I prob won't try this until next week sometime anyways. Is your friend called Graham and does he have 3 Audis? I hear he's a good guy.[/quote:2jlairqd] No, its not Graham. I'll try and get hold of the spanner. I'll be in touch. Al Quote Share this post Link to post Share on other sites
