stevef182 0 Posted October 7, 2008 i want to increase the stopping power of the VR with some new brakes, but cant really afford to go for larger ones yet, can anyone recommend some decent disks and pads that will make a noticable difference from the stock ones.. Quote Share this post Link to post Share on other sites
JayGT 0 Posted October 7, 2008 Pretty sure you can find 288mm brakes from a late golf for peanuts. Add goodridge hoses and you are laughing! Should have change from £150 for that little lot and the increase in pad size is where you'll benefit... Quote Share this post Link to post Share on other sites
g60karmann 0 Posted October 7, 2008 to notice a real difference you will need more surface area, so larger discs are the way to go, but better discs and pads will improve things a little. to help give a better feel braided hoses and some dot 5.1 fluid would be a good idea, cheap and easy to do. as for discs try to stay away from drilled as they will squeak a lot if used for daily driving, grooved are alright but personally I would stick with brembo solid discs. as for pads I can recommend mintex extreme. Quote Share this post Link to post Share on other sites
Leonard 0 Posted October 7, 2008 Goodridge hoses, standard discs and more aggressive pads. I recommend EBC red stuff or Ferrodo DS2500 Quote Share this post Link to post Share on other sites
jamminvr6storm 0 Posted October 7, 2008 The 288mm set up not only gives bigger disk area but they also have bigger pistons in the calipers. Quote Share this post Link to post Share on other sites
The_Dude 0 Posted October 7, 2008 so what advanatges do getting the goodridges give? Quote Share this post Link to post Share on other sites
Leonard 0 Posted October 7, 2008 so what advanatges do getting the goodridges give? Better pedal feel. Quote Share this post Link to post Share on other sites
Alexander 0 Posted October 7, 2008 I noticed a definite improvement with Black Diamond discs and pads. Quote Share this post Link to post Share on other sites
jamminvr6storm 0 Posted October 7, 2008 I noticed a definite improvement with Black Diamond discs and pads. I use Black Diamond too... Combi Disks and Preditor pads! Quote Share this post Link to post Share on other sites
Leonard 0 Posted October 7, 2008 Sorry I have to say that my std discs and uprated pads are better than the BD discs and uprated pads that I used to have. The BD dscs just eat your pads away. Better to have some nice aggressive pads and std discs that you can replace cheaply IMO. Quote Share this post Link to post Share on other sites
jamminvr6storm 0 Posted October 7, 2008 Each to their own, I find standard disks warp to easily! Only dowside with Black Diamond, the pads take ages to warm up.... Quote Share this post Link to post Share on other sites
The_Dude 0 Posted October 7, 2008 I would personally avoid all grooved/drilled discs as they eat away at the pads quicker and give less surface area for braking. There is an arguement about brake fade, but when was the last time you got serious brake fade? For me, I've only ever got it on the 'Ring, where I warped my discs anyway! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 7, 2008 Wasn't just me that had a bad warping habit then :lol: 280s, 288s, 312s....warp factor 5'd them all! I must drive too fast :D Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 7, 2008 I would personally avoid all grooved/drilled discs as they eat away at the pads quicker and give less surface area for braking. There is an arguement about brake fade, but when was the last time you got serious brake fade? For me, I've only ever got it on the 'Ring, where I warped my discs anyway! Sorry chap, my 312s used to fade frequently..... one common scenario was coming off a particular slip road at 100mph, which was downhill. A big work out for any brakes! But the 312s couldn't hack it all. Not many brakes resist fade on that particular road. But I hate to say it, I can barrel down that road at 130mph with AP racings and they just do not fade at all......ever. Had them on for nearly 3 years now, second set of pads, with grooved discs :D But as I say, I think I just drive too hard..... Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted October 7, 2008 ^^^^ All on your own private test track of course Kev! :lol: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 7, 2008 Yeah my private track being the M25 :lol: Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted October 7, 2008 Ok so which of the M11 slips is that then! Quote Share this post Link to post Share on other sites
Leonard 0 Posted October 7, 2008 Sorry chap, my 312s used to fade frequently..... one common scenario was coming off a particular slip road at 100mph, which was downhill. A big work out for any brakes! But the 312s couldn't hack it all. Not many brakes resist fade on that particular road. But I hate to say it, I can barrel down that road at 130mph with AP racings and they just do not fade at all......ever. Had them on for nearly 3 years now, second set of pads, with grooved discs :D But as I say, I think I just drive too hard..... That is a different matter especially if you are running AP calipers. They are probably the best brakes you can buy! I dont really think it is a fair comparison to a std brake upgrade LOL Quote Share this post Link to post Share on other sites
The_Dude 0 Posted October 7, 2008 I would personally avoid all grooved/drilled discs as they eat away at the pads quicker and give less surface area for braking. There is an arguement about brake fade, but when was the last time you got serious brake fade? For me, I've only ever got it on the 'Ring, where I warped my discs anyway! Sorry chap, my 312s used to fade frequently..... one common scenario was coming off a particular slip road at 100mph, which was downhill. A big work out for any brakes! But the 312s couldn't hack it all. Not many brakes resist fade on that particular road. But I hate to say it, I can barrel down that road at 130mph with AP racings and they just do not fade at all......ever. Had them on for nearly 3 years now, second set of pads, with grooved discs :D But as I say, I think I just drive too hard..... OK, I stand corrected then....guess I'm not as much of a loon as you are! But i find fade is much less noticable than on my old disAstra Gsi at any rate. Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted October 7, 2008 Private road I take it? :grin: Quote Share this post Link to post Share on other sites
jamminvr6storm 0 Posted October 7, 2008 Private road I take it? :grin: D Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted October 7, 2008 Britain's own 'Ring! Quote Share this post Link to post Share on other sites
jamminvr6storm 0 Posted October 7, 2008 Hell yeah... LOL Quote Share this post Link to post Share on other sites
Leonard 0 Posted October 7, 2008 LOL I thought the M25 was fully average speed checked up!? Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted October 7, 2008 Loads around M3 and M4 junctions. Some of it are surprisingly camera free though. Quote Share this post Link to post Share on other sites
