MonkeyVR6 0 Posted November 3, 2008 I've recently noticed that when I accelerate hard, really hard, in 1st (maybe even 2nd, I'll have to check) that there is a loud thud/metallic bang...nothing is/has been affected, however after accelerating away in such a fashion when I next brake there is a similar noise, just not as violent. :help: When I brake hard as per normal (emergency or my wife is navigating) there is no noise, when I'm in-gear and I accelerate there is no unusal noises. It just seems to be when I'm accelerating away from a standstill or barely moving. Help chaps...I haven't got a clue what this cold be?! Quote Share this post Link to post Share on other sites
bananawhip 0 Posted November 3, 2008 What part of the car does it come from? Silly question I know but is everything 100% secure (battery, toolkit/jack, etc) as it just sounds like it's a large object moving from the front of the car towards the back, then back again when you brake. It would only thud in lower gears as higher gears wouldn't give it the shunt it needs, then as cars deccelerate quicker then accelerate it wouldn't take that much of a heavy break to bring it back again. Not very technical but just a thought. Quote Share this post Link to post Share on other sites
carpoid 0 Posted November 3, 2008 One of your engine mounts ?? Sounds like the noise mine made when it started to go. Do you know if any have been replaced ? Quote Share this post Link to post Share on other sites
flusted 0 Posted November 3, 2008 sounds like front mount, try putting handbrake on and with bonnet up look for excessive movement by lifting the clutch to biting point Quote Share this post Link to post Share on other sites
MonkeyVR6 0 Posted November 3, 2008 Right, I'll get someone to check for me - hopefully tonight - to see if I've got a mount going/gone in the engine bay. How expensive are these things to replace? I assume replacing a mount underneath the engine is going to cost a few quid :sad: Quote Share this post Link to post Share on other sites
was8v 0 Posted November 3, 2008 The bolt through the rear of the front wishbone was loose on my car causing similar symptoms, also a knock over cobbles. This was after having the wishbones changed out. Check all your suspension bolts are torqued up! Quote Share this post Link to post Share on other sites
Leonard 0 Posted November 3, 2008 Right, I'll get someone to check for me - hopefully tonight - to see if I've got a mount going/gone in the engine bay. How expensive are these things to replace? I assume replacing a mount underneath the engine is going to cost a few quid :sad: Defo sounds like front engine mounts. It is a reasonably expensive job to do with uprated Vibra Tech mounts. However it is worth doing. If it is the mounts you should probably be able to feel a shunt through the drivetrain/gearstick changing from 1st to 2nd Matt Quote Share this post Link to post Share on other sites
g60karmann 0 Posted November 3, 2008 one way to check for yourself is to open the bonet and try slowly pulling away you should be able to see excessive movement of the engine, but i would put money on it being the front engine mount, my bbm front mount bolt came off twice now :( Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 3, 2008 i would place rather large money on this being your front engine mount. My golf did exactly the same - the engine has a large torsion (twist) force back towards the firewall (just watch any turbo'd engine on a dyno) which places a large tension force on the front engine mount. if the bolts has fallen out or the mount is dead, either the bracket (or bracket with mount attached!) will rise up, and then subsequently drop down with a thud or a bang onto the front cross member when you let off the gas or change gear. This is because 1st gear is so short and thus has the largest amount of torsion or twist force applied to the engine. hope that makes sense. Jon. Quote Share this post Link to post Share on other sites
bananawhip 0 Posted November 3, 2008 OK mine may have been a fairly retarded answer but it was 3am and I couldn't sleep Didn't even think of the engine mount Quote Share this post Link to post Share on other sites
Leonard 0 Posted November 3, 2008 OK mine may have been a fairly retarded answer but it was 3am and I couldn't sleep Didn't even think of the engine mount Its always good to check the smaller things first! :) Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 3, 2008 bananawhip, perfectly plausible mate. I've known batteries to shift around a lot! Mine fell off the perch once and onto the shift tower, couldn't get 1st or 2nd until I stopped an investigated! :nuts: Quote Share this post Link to post Share on other sites
