Rosso 0 Posted December 7, 2008 alright peeps, just bought an ABF engine for my rado as the KR...well, died a death really.lol. wanting to get a 4branch fannymould for it but struggling to find one for a RHD model. does anywhere do these or would i have to have one made up? cheers, Ross.x Quote Share this post Link to post Share on other sites
oldskoolkool 0 Posted December 8, 2008 Hi mate I've been looking for one too there is millions on flebay but there mostly shite one there are a couple of racelands tho but I'm guessing you have looked there as for me I may well make a mild steel one as it's cheaper and the is not alot different to stainless!?!! Quote Share this post Link to post Share on other sites
flusted 0 Posted December 8, 2008 I used a tsr stainless mk2 golf 1, should be fine if not runing a cat although abf is 16mm taller block Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 8, 2008 ... although abf is 16mm taller block this is what I was wondering, do 4 branches clear the rack/subframe/bulkhead when fitted to the taller ABF block, if not then I'd heard of people modding the mounts to drop the engine a little to compensate. Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted December 8, 2008 Couple club guys have ABF'd their MK2's and the stock Mani apparently flows plenty good enough! And clears everything too! Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 8, 2008 there's no doubt you'll change the torque characteristics with a 4 branch, maybe not in the desired way, I personally have found a flowed/polished standard 16v cast iron manifold and standard downpipe is excellent, and you are definitely not going to get any problems with noise, cracks, heat issues etc, but in the quest for peak power everyone seems prepared to ditch the oem bits, and new 4 branches are shiny of course :) Quote Share this post Link to post Share on other sites
Rosso 0 Posted December 11, 2008 I used a tsr stainless mk2 golf 1, should be fine if not runing a cat although abf is 16mm taller block so a mk2 golf one would fit? thort the bulkheads were different so one wouldnt fit? or is that me bein dumb? :scratch: Quote Share this post Link to post Share on other sites
flusted 0 Posted December 11, 2008 yep i defo used a mk2 1 Quote Share this post Link to post Share on other sites
Ashley 0 Posted December 13, 2008 tsr said a kr 16v golf one that they do will fit a 16v kr or 9a rado not sure about the abf tho although g-werks do a 16v 4 branch that has a bit of adjustment in lengh and they told me it would fit abf too but when i spoke to them 6 months ish ago they needed enough orders to make some hth Ash Quote Share this post Link to post Share on other sites
