chrishill
coilover recomendations
i know this has probably been covered a million times before but...
I'm looking at suspension options, and i think coilovers are going to be the way to go, given that the biggest drop on springs/dampers is about 40mm and to me thats just not low enough on 17's!
Not looking to spend a fortune, around the £500 mark, so whats good and what should i avoid?
The Supersport coilovers from Venom get a big thumbs up from me... 8) about £400 IIRC, they're not stiffness adjustable though, only height...
Venom do shock/springs kits that allow upto an 80mm drop...
I'm running the 55mm springs at the mo...
is that the spax kits bally?
Its there own kit Chris, ring Richard @ venoms & he'll give you more info... let me no if you want the no..
Found a venom advert in PVW, they do a 55mm drop :D nice price too...
so, once i've got them where can i get them fitted? i'm guessing kwikfit cant do it for me!
Hi Mate, from what I got told by them, Kwikfit don't fit parts supplied by a customer.. incase the part goes wrong they don't want to take responsibilty! :roll:
A local garage or mechanic can fit a set of shock/springs in a few hours, as long as the nuts aren't too rusted up :roll:
