rookierod 0 Posted May 26, 2009 hi does the 2.0 16v 93 have any camber ajustment mine is lowered and beleve camber cud be way out as have very light steering and feels like it trys to pull into concers? if not is thee a way to make them ajustable? or could be something else and not camber? thanks ian. Quote Share this post Link to post Share on other sites
yeti 0 Posted May 26, 2009 hi does the 2.0 16v 93 have any camber ajustment mine is lowered and beleve camber cud be way out as have very light steering and feels like it trys to pull into concers? if not is thee a way to make them ajustable? or could be something else and not camber? thanks ian. front wishbone ball joint plate... 3 small bolts per side allow the ball joint to move in and out of the wishbone, take the car to a 4 wheel alignment specialist and get the car properly set up - it makes a world of difference! Quote Share this post Link to post Share on other sites
rookierod 0 Posted May 26, 2009 . thank for reply i will get it looked at would this be cause of trying to pull and very light steering? Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 26, 2009 no, the camber is set by the suspension leg to hub bolts, the two big 18/19mm ones, not the ball joint to wishbone, that will alter the track. You can use camber correcting bolts from VW if you have problems obtaining enough negative camber with the standard setup. Quote Share this post Link to post Share on other sites
Henny 0 Posted May 26, 2009 yup.... also check tyre pressures... too high will make the steering very light and give sod all feel... :) Quote Share this post Link to post Share on other sites
rookierod 0 Posted May 26, 2009 any one no the part nubers or what to ask for the bolts? are they cam shape shafts then? have checked the pressures, i was guess was steering rack but got told cud be camber, camber sounds cheaper to look into first, though can get a rack fr 35 deliverd. Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted May 28, 2009 just have a gander at the camber; ie the suspension shock bottom two bolts; you'll notice the hub/disc will tilt away from you (top to bottom) if those bolts are undone. But if you're asking the question, then I doubt you've got the kit to do it - its not just by eye. I'd pay someone 40 to laser-align it up for you; they might check toe etc then too. I presume your tyres have worn oddly - if so, you'll need new rubber on there, or prepare to put up with more odd steering. Quote Share this post Link to post Share on other sites
rookierod 0 Posted May 28, 2009 yeah n/s inner has worn, but o/s ok but wheel bearing is hanging out so that could allow the wheel to sit flater on graound? have had tracking done yet as i am gonna change bearing at weekend and the go get it all lined up. havent had time to change it yet with work and the misses working nights n 2 kids lol Quote Share this post Link to post Share on other sites
