Toad
Gruvenparts crack pipe.
Out of interest... Has anyone else noticed corrosion on the outside of their crack pipes?
I know mine is a bad example, having been sat for 18 months, but I was a little disappointed by the level of the corrosion I found...
i've not looked at it since it went in, but i will check it out now you have said this.
is it crusty corrosion or just stained?
Mine is covered in crusty corrosion at the joint with the water pump that needed removing with a screwdriver, and is pitted along the length. :(
