yacobwood 0 Posted June 7, 2009 Firstly my wipers made two passes quite slow then went back to normal speed, then my power steering cut out momenterily :shrug: seems fine now i was just a bit puzzled Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted June 8, 2009 electrical gremlin? any good with the wiring diagramme? Quote Share this post Link to post Share on other sites
Henny 0 Posted June 8, 2009 I'm guessing it was raining heavily, and you probably had your lights, radio and heater blower on? time to tighten/replace your alternator and P/S belt/s.... ;) Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 8, 2009 yep, sounds like spray hitting the aux belts. Quote Share this post Link to post Share on other sites
yacobwood 0 Posted June 8, 2009 Yes it was raining heavily. so much so my fan belt let out a little (but loud) sqeal :mad2: Quote Share this post Link to post Share on other sites
Henny 0 Posted June 8, 2009 there's your problem then... the water made the aux belts loose grip on the pulley for the alternator and the PS pump (the two hardest to turn pulleys) so you lost charging power and power steering... Check the condition of your belts and the tightness of 'em too... At least it's a simple one to fix... 8) Quote Share this post Link to post Share on other sites
yacobwood 0 Posted June 9, 2009 Thanks alot. i was worryin for a while there :clap: Quote Share this post Link to post Share on other sites
