blue95
Ideal engine oil temp? 20vt or others
Bit of background, I am running the BAM 20vt lump, uses a rallye rad and inetrcooler. I seem to be getting water temp of between 85C-95C and have struggled to get the oil temp above 86C.
I am running VW synta gold engine oil, the engine gets up to temp pretty quickly so am pretty sure its not the thermostat.
Is this oil temp too low?
What do other 20vt peeps get?
Water seems fine
oil seems fairly fine too; but if in doubt you can ask manufacturer for optimum working temps (if it doesnt say on tin). Alternatively, you could try a semi synth (keeping the fully in a tub)
No,that's fine.
Thanks for your replies fellas!
Had some fun in the Corraddo today with Carrera 4s LOL...the oil temp does go to 100C LOL
