watto1986 0 Posted August 7, 2009 Hello All Could anyone help? I need to change the fuel filter on my Corrado VR6. Is the a quick guide anyone is aware of? Thanks Chris Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 7, 2009 Not sure if it helps, but some guy with a jetta VR6 did a guide here: http://forums.vwvortex.com/zerothread?id=1276409 Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 7, 2009 its only a coulple of hose clips on the fuel filter and a clamp that holds the filter on....jack up the car at the offside rear and have a look it will explain its self. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 7, 2009 http://wiki.the-corrado.net/fuel_filter_change_vr6.html Quote Share this post Link to post Share on other sites
fla 9 Posted August 7, 2009 you may find that one or other of the clips get stuck and will not let you pull the plastic housing down. Be careful and carefully lever the clip out. Then as above, its an easy swop. Use some copper grease on the new jubilees, not that you will need to open them for another 10 years! Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 7, 2009 @supercharged Any chance you work at g-werks or? Just thought I'd ask :) Quote Share this post Link to post Share on other sites
VR6 0 Posted August 8, 2009 No, he's just trying to bag some discount :lol: Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 8, 2009 No, he's just trying to bag some discount :lol: Haha, ok.....lol...:) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 8, 2009 you may find that one or other of the clips get stuck and will not let you pull the plastic housing down. Be careful and carefully lever the clip out. Then as above, its an easy swop. Use some copper grease on the new jubilees, not that you will need to open them for another 10 years! Use proper fuel line clips not Jubilee's if possible, Jubilee clips are not constant tension and will lead to the fuel line cracking. G-werks - Hehe - yeah just a bit of free advertising as they have helped me out a few times! Quote Share this post Link to post Share on other sites
watto1986 0 Posted August 9, 2009 Cheers for the advice guys! The problem was that the pipe was deteriorated around the clips. I put proper fuel pipe clips on and hopefully have now solved the leak! Back to driving! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 9, 2009 did mine today, the fuel lines were clamped on with a little clip with a screw in it? is that right? Quote Share this post Link to post Share on other sites
watto1986 0 Posted August 9, 2009 Thats what I used, they were jubilee clips but I think this is what caused the leak. Quote Share this post Link to post Share on other sites
