snattrass 0 Posted August 9, 2009 I know it seems really daft but do I just turn the pins at the top of the mounting threads bolt with an adjustable or something? Is it clockwise for more firmness or clockwise for more softness? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 9, 2009 you should get a little knob with them that sits on the fronts, the rears have to be adjusted off the car. I should have a manual and the knob around that i don't need anymore well thats how it was when i had them on a corsa Quote Share this post Link to post Share on other sites
ben16v 0 Posted August 9, 2009 i dont use my rear speakers so have removed them and can adjust the back through the speaker grills! http://rpmspeed.com/images/Koni-SA.BMP this pic looks anti clockwise for firm! Quote Share this post Link to post Share on other sites
snattrass 0 Posted August 9, 2009 Cheers guys thats helpful... Mine don't have that knob... does it really make all that much difference - there's only about 3 turns? Does the ride firmness/softness change so that it's noticeably softer? Quote Share this post Link to post Share on other sites
andy 0 Posted August 9, 2009 It should be 2 full turns from hardest to softest, and yes it does make a fair degree of difference to ride quality and handling between the two extremes. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted August 9, 2009 Makes quite a difference. Just use some pliers if you haven't got the adjuster ;) Quote Share this post Link to post Share on other sites
shaunVR6 0 Posted August 9, 2009 ive got 3 spare if u want a one mate just had them fitted you get 1 with each corner :D Quote Share this post Link to post Share on other sites
snattrass 0 Posted August 11, 2009 Just removed my rear speakers and left the speaker grills sitting in for cosmetics...can then just pop them off and get the pliers or adjustable on the top bit... good tip... thanks.. anyone with a key the wouldnt mind me having pm me - that would make life a bit easier.. thanks guys Quote Share this post Link to post Share on other sites
fla 9 Posted August 11, 2009 i thought that the rears had to be compressed and then turned to adjust the softness? Only the fronts were adjustable from the top? Quote Share this post Link to post Share on other sites
