daves16v 1 Posted September 7, 2009 VAG Front wheel bearing kit for 2L 16v Rado, could someone identify the parts contained in the kit from left to right (see photo). I know what most of them are but unsure of some. Thanking you kindly. Quote Share this post Link to post Share on other sites
tyler 0 Posted September 7, 2009 bolt,nut,nut,nut,nut,nut and screw :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 7, 2009 Bottom Ball joint pinch bolt, TRE nut (35Nm), Pinch bolt nut (50Nm), Hub Nut (265Nm), 2 x suspension strut nut (95Nm) and Brake disc retaining torx screw Should also be a tube of grease for the CV splines. Quote Share this post Link to post Share on other sites
Swompy 0 Posted September 7, 2009 bolt,nut,nut,nut,nut,nut and screw :lol: :lol: :lol: :lol: legend :lol: :lol: :lol: Quote Share this post Link to post Share on other sites
DanVW 0 Posted September 7, 2009 Sorry Dave I have no idea but have to say Tylers post was the funiest thing I have seen all day :lol: :lol: Quote Share this post Link to post Share on other sites
daves16v 1 Posted September 7, 2009 Thank you 'Supercharged'. Up yours 'tyler' ...........only kidding, I nearly laughed tho. Quote Share this post Link to post Share on other sites
daves16v 1 Posted September 8, 2009 Should also be a tube of grease for the CV splines. Yep got that too. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 8, 2009 bolt,nut,nut,nut,nut,nut and screw :lol: short changed there, really should be a bearing in there somewhere :scratch: Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted September 8, 2009 bolt,nut,nut,nut,nut,nut and screw :lol: short changed there, really should be a bearing in there somewhere :scratch: :lol: :lol: :lol: :lol: :lol: Quote Share this post Link to post Share on other sites
daves16v 1 Posted September 8, 2009 bolt,nut,nut,nut,nut,nut and screw :lol: short changed there, really should be a bearing in there somewhere :scratch: :lol: :lol: yeah I did get that unimportant part too. Quote Share this post Link to post Share on other sites
pete_griff 0 Posted September 8, 2009 if you're doing the bearings i would also look at taking the abs rings off and refurbing/renewing them as you won't be able to do them any other time. that means you'll also need 3x new abs rings screws and possibly a new abs ring. don't forget to get it all aligned properly again after too :wink: Quote Share this post Link to post Share on other sites
daves16v 1 Posted September 8, 2009 if you're doing the bearings i would also look at taking the abs rings off and refurbing/renewing them as you won't be able to do them any other time. that means you'll also need 3x new abs rings screws and possibly a new abs ring. don't forget to get it all aligned properly again after too :wink: I'm doing 4 to 5 stud conversion so they'll have to come off anyway for modding but I think I'm gonna get new rings anyway. Already got new screws and yes I'll get it all aligned afterwards. Thanks for your comments. Quote Share this post Link to post Share on other sites
ashbev 0 Posted November 11, 2009 pinchbolt and nut , track rod end nut , hub nut , 2 drop link nuts , brake disc screw :) Quote Share this post Link to post Share on other sites
Wompa 0 Posted November 12, 2009 HAHA!! Tyler, awesome :notworthy: Quote Share this post Link to post Share on other sites
