culshaw
MOT Pre test results...
I just got a phone call from local garage about the parts corroded/wrong with my car the parts i can remember are as follows:
Both rear axle bushes (split or corroded can't remember what she said)
Fuel filter corroded
Front brake hoses corroded (maybe rear as well)
Front gasket leak (i think that's what she said)
Front discs & pads
Front o/side caliper seized
Front & rear brake compensators..
Can someone give me a clue of how much this will set me back if i did it myself?
(Put in drivetrain because most is drivetrain)
rear bushes around £30 pounds half a days work
fuel filter 10.00 20 minutes
pipe work 10-20 2hrs
disc and pads 3hrs
caliper do the same time as pads ect 60
so around 200 uk pounds not to bad for another yrs motoring
1. Both rear axle bushes (split or corroded can't remember what she said)
2. Fuel filter corroded
3. Front brake hoses corroded (maybe rear as well)
4. Front gasket leak (i think that's what she said)
5. Front discs & pads
6. Front o/side caliper seized
7. Front & rear brake compensators..
Could try phoning VW for some quotes for parts, for thier Servicing dept. But from memory prices from GSF about 4 years ago were: 1. expensive considering labour, 2. see Wiki for How to, cost £15, 3. normal hoses circa £40, 4. ?, 5. Discs £60, pads £40 for pairs on front, 6. Re-con caliper circa £60, 7. £? Thats starting at £200 just to do the brakes, let alone the axle bushes and fuel filter. And assuming you've the tools.
But yes, quite normal work for a Corrado.
half of that stuff isnt a mot fail though...might want to find a more honest garage
leaky gasket dont matter , and niether does a rusty fuel filter unless its leaking
Yea it's more peace of mind, plus if i get most of it done car should be sorted for a couple of years picked the car up couple of weeks ago and here's the definitive list:
OSF caliper seized upgrading to vr6 calipers
Front discs + pads g60 discs
Sump gasket leaking
[strike:2e5zbyod]Rocker cover gasket leaking[/strike:2e5zbyod]
Front to rear brake pipe corroded
N/s to O/s Rear B/pipe corroded
[strike:2e5zbyod]Brake compensator seized[/strike:2e5zbyod] (chiller1)
Brake hose at reservoir chaffed through ? is this just meaning the cotton is fraying?
Both rear axle bushes split
Both rear wheel bearings
Fuel pipes to filter corroded
Fuel regulator corroded
Rear brake bads
N/s/f abs sensor insecure
Hole in floor near nsf sill
N/s/f ball joint bolt loose
Exhaust manifold cracked
anyone who's got a 9a exhaust manifold and a fuel reg drop me a pm please!
Let us know if you get stuck; most of that is doable DIY. (see Forum wiki and Haynes for Passat if its teh 9A)
Yes hose is displaying its innards - get new one.
Sounds like you'll become on first name basis with your local VAG then. :)
