mort1414 0 Posted October 10, 2009 i decided to day that i would test fit my new brakes passat climatronic wiring diags.pdfImage047.jpg[/attachment:3vsvrnbt] have found a few problems though there is a gap between the carrier climatronic wiring-Golf from May 01.pdfImage042.jpg[/attachment:3vsvrnbt] could this be solved with the spacer used when fitting 312 audi callipers? also there catching on the alloy really dont want to use spacers anything i can do? 2.8l 24v Climatronic system.pdfImage051.jpg[/attachment:3vsvrnbt] Image041.jpg[/attachment:3vsvrnbt] cheers mort Quote Share this post Link to post Share on other sites
volksworld13 0 Posted October 10, 2009 for the calliper it looks as if your gonna have to find a spacer/washer to make it fit well, and as for the alloys touching you will probably need a thin spacer for that as well, as when fitting all mods you can run into problems, im not sure if there is any other way around it. Quote Share this post Link to post Share on other sites
culshaw 1 Posted October 10, 2009 i'm gonna have this issue soon too, so help appreciated! Quote Share this post Link to post Share on other sites
mimjed 0 Posted October 12, 2009 not something ive attempted but washers and wheel spacers is what id go with. just hope youre not in a hurry to get back on the road. Quote Share this post Link to post Share on other sites
mort1414 0 Posted October 12, 2009 nope not in a hurry as my standard brakes are still on i cant use spacers as the wheels are to wide for the car already i was thinking if the calliper was further out and i used a bigger disk i would have more clearance Quote Share this post Link to post Share on other sites
mimjed 0 Posted October 12, 2009 like i said not something ive attempted, but assumption would be that bigger discs may do what your after, depends on design of wheel really. but you need someone who knows what there on about before you part with cash. err unfortunately id say go on edition38 and have a search through mk2 golf threads, maybe even post up the same on there. Quote Share this post Link to post Share on other sites
Henny 0 Posted October 12, 2009 As I see it, you have two options: 1) Space the calliper to suit the disks you have and then put a spacer in to move the wheel away from the calliper (yes, I know you don't want to do that, but it's what most people have had to do fitting this kind of calliper 2) Space the calliper even further back so they'll clear the wheels, and get some different offset disks (which sit further back from the wheel mounting face) to suit. This will give you the clearance you need on the wheel, and as you're going to have to use spacers on the calliper mounting anyway, seems a logical solution... If you go with option 2, you may have to go with custom disks, in which case you may want to go with seperate bells and disks, which normally has the advantage of being lighter and so reducing unsprung weight... 8) Good luck anyway... :) Quote Share this post Link to post Share on other sites
mort1414 0 Posted October 12, 2009 ok the red measurement is 12mm blue measurement is 22.5mm Image042measure.jpg[/attachment:1t46agu4] Quote Share this post Link to post Share on other sites
