Kempy 0 Posted November 16, 2009 How do I remove the injectors from the lower manifold, for powdercoatings? :) thanks its a 9a valver Quote Share this post Link to post Share on other sites
Wullie 1 Posted November 16, 2009 If it's a KR they just pull out, there not secured with anything else. Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 16, 2009 how about the bits the injectors fit in? will they melt when cooked in oven, they arent metal are they? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 16, 2009 9a should have a securing clip on each injector, remove these first and then pull the injector, or prise using the hex of the union for leverage on a warm engine and they should pop out. The inserts can be removed with a large allen socket, something big like 13mm cant remember exactly. Quote Share this post Link to post Share on other sites
Jim 2 Posted November 16, 2009 There's a few parts to the lower manifold which hold the injectors in place. Firstly there are little metal clips sitting on the injector line above each injector - just prise these off and buy new ones to replace them. Inside the lower part of the manifold, there are metal crowns which the injectors plug into. Once the injectors have been pulled, and the lower part of the manifold removed, these can be unscrewed with an appropriate sized insert. Attached to the crowns, there are little plastic tubes - buy new ones of these from VW as they go really brittle and in many cases can be cracked and damaged. Pulling them is a right game, as is refitting them - a good tip I found for putting them back in was to insert the injector into the hole and then lever them in! There are lots of places all round the inlet to give you leverage. Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 16, 2009 cheers chaps. the manifold is off the car anyway, how will I be able to warm it up? I see how to pull the injectors out but I wondering about the plastic bits, I imagine they will just brake Quote Share this post Link to post Share on other sites
aide 0 Posted November 16, 2009 hair dryer or heat gun you shouldn't need to heat to get the other stuff off, the plastic sleeves just push out backwards, the inserts can be unscrewed with a large alan key/ hex driver and because i'm a silky salesmen - i have a clean/ complete set of the inserts and sleeves for sale if you need :D Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 16, 2009 are they used? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted November 17, 2009 If it's a KR they just pull out, there not secured with anything else. :shock: Not disputing this at all - but what the hell stops them getting blown out then? How tight a fit are they? Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 17, 2009 they are held in with rubber bungs/rings Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 17, 2009 If it's a KR they just pull out, there not secured with anything else. :shock: Not disputing this at all - but what the hell stops them getting blown out then? How tight a fit are they? if anything they get sucked in :lol: unless you really have a problem, your inlet valves should be shut when the piston comes up, so nothing's going to be pushing those injectors out, often what happens when the seals get old and hard is they leak air in and make the engine run lean/cause idle problems Quote Share this post Link to post Share on other sites
aide 0 Posted November 17, 2009 are they used? yep used but clean, can get a piccy if you need Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 17, 2009 are they used? yep used but clean, can get a piccy if you need yes please Quote Share this post Link to post Share on other sites
odub 0 Posted November 17, 2009 just to jump in on this, how often is it worth replacing the inserts, o-rings, etc? I don't particullarly know the history of the engine in mine Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 17, 2009 Some WD40 is very handy when putting them back in! Quote Share this post Link to post Share on other sites
Jim 2 Posted November 17, 2009 If the deal with aide falls through I've got a set of 4 brand new metal crowns / inserts which screw into the inlet - bought them but didn't use them as the ones already in mine were clean enough! Lemme know if you're interested! Quote Share this post Link to post Share on other sites
Jim 2 Posted November 17, 2009 No idea! :) £10? Think they cost about £20 from VW.. Quote Share this post Link to post Share on other sites
aide 0 Posted November 17, 2009 piccy, was looking £4 in for sale thread Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 17, 2009 and they are removed how? :grin: Quote Share this post Link to post Share on other sites
aide 0 Posted November 18, 2009 and they are removed how? :grin: the sleeve bits just pull off the top of the screw insert things, or push backwards out the manifold if that's what you mean? Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 20, 2009 these crowns, will they melt in the oven when getting baked after the powdercoat? cheers Quote Share this post Link to post Share on other sites
aide 0 Posted November 20, 2009 am getting a bit confused - the brass inserts can be unscrewed from the manifold, the plastic sleeves clip onto the top of the brass inserts, or if disconnected they can be pushed backwards out the manifold?! Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 20, 2009 its alright Ive removed the inserts and the brass crowns now so the oven shouldnt be a problem now :lol: Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 24, 2009 found out its £30 an injector :lol: :bad-words: so is there a way to test the spray etc on my old ones, maybe clean them up a bit? Jim I'll still have those crowns though 8) Quote Share this post Link to post Share on other sites
