culshaw 1 Posted January 19, 2010 I've taken my lower intake manifold off but can't suss out how to pull the fuel injectors out from their housing as i need them to go into the new manifold (unless its just brute force), i also need to remove one of the injector inserts (as the fourth on the new mani's insert has snapped) to put in the 50mm lower intake that i have waiting to go on so any help is appreciated (again). Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 19, 2010 get them warm and pull, it's just a rubber o ring sat in a groove holding them in place old o rings get hard so a little force on the edge of the injector top (hex shaped bit) can help in lifting them out inserts need a large hex key to remove Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 19, 2010 just gotta use brute force as they are held in with rubber rings. I used molegrips and heat for the inserts, but you can use a large allen socket I believe Quote Share this post Link to post Share on other sites
mort1414 0 Posted January 19, 2010 will take your mani 2 work wednesday and get it out for you if yo want ian Quote Share this post Link to post Share on other sites
culshaw 1 Posted January 19, 2010 Awesome thanks, is the hex 14mm? Quote Share this post Link to post Share on other sites
mort1414 0 Posted January 19, 2010 got em all at work so sure i will get it out got them books for u aswell pub l8r? Quote Share this post Link to post Share on other sites
