PeteL 0 Posted February 5, 2010 Guys Bit of a strange one...Got a buzzing noise coming from the VR6, it sounds electrical but im unsure. The symptoms are as follows: - It happens constantly when moving and when stationary. Turn off the ignition it stops. - Seems to be coming from outside the car not inside (although you can hear it in) as louder outside. - Seems to be coming from underneath at the rear (i know this is the engine section but not sure where else to ask, mods please move if needed). - I notice the pitch changes very very slightly as you turn headlights on/off. - Car and everything on it is running fine. Any ideas? Really stumped. Cheers Quote Share this post Link to post Share on other sites
PeteL 0 Posted February 5, 2010 Just to add before somebody suggests, I have no headunit in it at the mo so it isnt the speakers :) Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 5, 2010 wasps nest .... sorry that no help is it Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 5, 2010 Do you have heated seats got a relay buzzing when my heated seats went dodgy?? Quote Share this post Link to post Share on other sites
PeteL 0 Posted February 5, 2010 No heated seats (I wish ;-)) I'll check out the fuel pump, thanks Mark. Any more suggestions? Quote Share this post Link to post Share on other sites
hodaz 0 Posted February 5, 2010 Easy way to check if its the fuel pump os take the cover off inside the boot then pull of the electrical connector and see if the noise is still there when ignition is on. Fuel pump would normally be a whine more than a buzz. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted February 5, 2010 Another for fuel pump! Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 5, 2010 sounds like fuel pump , but make sure its not the auxillary waterpump under the bonnet! Quote Share this post Link to post Share on other sites
PeteL 0 Posted February 8, 2010 thanks chaps I am pretty sure its the fuel pump. Whats the score with replacing it? simple for a novice? i suspect not!!! what about cost? cheers Quote Share this post Link to post Share on other sites
PeteL 0 Posted February 8, 2010 viewtopic.php?f=1&t=68060&hilit=fuel+pump Just found this thread, answered my questions. Cheers. Will post up how I get on. Quote Share this post Link to post Share on other sites
PeteL 0 Posted February 11, 2010 Had Cornelius at German Auto Engineering in Portsmouth check the car today. Fuel pump is ok, the noise is not loud enough to be a sign of a problem. Had the pressure checked and its all ok. Fuel filter and a fuel pipe was replaced and the car is now running much better. Thanks Quote Share this post Link to post Share on other sites
