Fanjita
Help! - 288mm Carriers
Hi all,
Just been chucking all the 288mm parts onto my C, but I've hit a bit of a brick wall here.
Can anyone tell me if I have the wrong carriers and where I should go to get the right ones?
Are these 312mm Carriers? The discs are 288mm
Cheers,
Jim
to me they look like 312mm.
If you measure from the outside diameter of the disk to the top edge of the pad will give you how much difference there is. if its roughly 30mm, then you need 312mm discs
Argh, yeah looks like they are 312mm carriers :brickwall:
Sorry it's just one thing after another.
So my two options are:
312mm Discs
or
288mm Carriers
Which option is cheaper?..lol
Dont know which is cheaper mate but if someone can confirm 312 will fit under 16 inch steels I'll swap yeah for my 288 carriers for your 312 as not bought discs etc yet
if that help any way :shrug:
I know a friend of mine has 312mms under his storm standard wheels, they're 16" aren't they?
Sounds like a plan, they're even painted red for you :clap:
standard speedlines are 15
just painted mine black!
Will have to paint them black too to match my callipers :lol:
if you want then mate I'll swap ya
Storm solitudes are 15" mate
312mms brakes need at least 16" wheels to fit
288mms fit snug under the 15" solitudes
Cheers john mine are 16 inch beetle wheels you seen them at elsecar I was trying to find that screw driver for Chris.
My bad yeah not speeds but still 15
That's just weird, he was telling me it definitely says 312mm conversion on one of his receipts?
He has the standard storm solitudes, is there any way at all they could fit?
lilfuzzer - would these 288mm carriers be available soon? I need to carry on with this work asap, cheers.
Perfect thanks!
Drop me your address by PM and I'll have yours sent off tomorrow also. If it's alright could you do next day delivery (if poss) and I will settle the difference for your postage, unless you want next day too. As you can see in the pic I have done a lot of work cleaning them up, your black paint should go on fine.
Cheers
Yeah i remember mate beetle steelies look the nuts on your raddo mate beefy!!
