jackvine
Oil Temp not working on VR6
Hi All
The oil temp on the mfa is not working all i get is the dashes which you normally get when the car is warming up, checked the wiring is still connected to the sensor and seems to be ok, is it likely to be the sensor or the mfa unit ?
I've just started experiencing a similar thing but it's intermittant. It started acting up some weeks back and has now completely stopped working, it's had a new sender about 3 months ago before it started playing up and all was well. I've put the old sender back in without success and now I'm back using the new sender. Weirdly it does sometimes work but doesn't give an accurate reading and that's using both old and new senders. Oh and I've cleaned the connector to the sender.
I haven't disconnected the battery as previously suggested so I might give that a go. Looks like it maybe dodgy wiring or a duff MFA?
Any thoughts?
