bigbroony 0 Posted July 28, 2010 My gear linkage is very sloppy and recently the lever sometimes baulks unless care is taken.After a quick Google I found that one problem is a missing linkage circlip.The one that actually locates the lever on the shaft.This is the case with my car. Does anyone have the part number of it or it's dimensions so I can get it from another source and not spend the rest of my life trying to explain to the dealers which bit I'm after. Cheers Alan. Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted July 28, 2010 If it's number 12 (which I think it is) it's N 908 159 03 gear_pic.PNG[/attachment:m7gp1y7f] Prob best wait for someone who's in the know to confirm before you order. Quote Share this post Link to post Share on other sites
bigbroony 0 Posted July 28, 2010 That certainly looks to be the very fellow for me. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 28, 2010 It is number 12 :) Think there are two versions though- my dealer wasn't sure which one it would be, so I bought them both (only a few pence). Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted July 28, 2010 It is number 12 :) Think there are two versions though- my dealer wasn't sure which one it would be, so I bought them both (only a few pence). In that case the other number is 012 327 6 :D Quote Share this post Link to post Share on other sites
_Meth 0 Posted July 29, 2010 I just used an e-clip from my toolbox that I had kicking around - its done the job for over a year now :lol: Quote Share this post Link to post Share on other sites
bigbroony 0 Posted July 29, 2010 So, what's an e-clip then? And more importantly where can I get them? Quote Share this post Link to post Share on other sites
carrots 1 Posted July 29, 2010 i made 1 for mine it made a massive differance to the gears :D Quote Share this post Link to post Share on other sites
_Meth 0 Posted July 30, 2010 An E- Clip is just a different type of circlip... Im not too sure where you owuld get one... its one of those things that I always have in large quantities, and is allways kicking around - but never know where they come from... Quote Share this post Link to post Share on other sites
carrots 1 Posted July 30, 2010 lol true :lol: Quote Share this post Link to post Share on other sites
_Meth 0 Posted July 30, 2010 I reckon its the same toolbox pixie that hides your 10mm spanner, only to replace it exactly where you have been looking - 5 minutes after you've given up trying to find it and bodged it with a 11mm :lol: Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 30, 2010 E clip has a middle bit (like the middle stoke in an 'E') and so holds the clip tightly in place. Later versions of the cable change 02A box had E clips on the gearlever pivot, with a small cut out in the centre to locate them even better and stop them pinging off presumably, VW obviously spotted the problem eventually :) Quote Share this post Link to post Share on other sites
bigbroony 0 Posted July 30, 2010 I've bought part number N 908 159 03 and it doesn't look to me as it will fit.I haven't offered it up to the shaft yet( fnarr fnarr). I'll have a better look tomorrow. Quote Share this post Link to post Share on other sites
_Meth 0 Posted July 31, 2010 You may be supprised, the clip does look very small but the recess it clips into is also fairly small. Quote Share this post Link to post Share on other sites
bigbroony 0 Posted July 31, 2010 Success! ! Clip now fitted.In true Clarkson style it needed a hammer though;but then doesn't everything worth doing?Haven't driven it yet.Went out for an Italian instead.I feel I'm on a winner as the gear lever actually moved when I'd finished. Quote Share this post Link to post Share on other sites
bully 10 Posted January 27, 2013 where can i buy this circlip.. noticed mines gone :( Quote Share this post Link to post Share on other sites
