VR6Pete 0 Posted January 17, 2011 (edited) As this topic is being covered over various areas of the forum, I thought I'd start off a thread where all information can be collated in relation to the problems and solutions with regards to the heater controls on the late Corrado (rotary controls). So if anyone has any tips / tricks for repairing / replacing the troublesome unit, please add your comments! Here's a few threads i've collated together from recent conversation. Heater Controls Only working on 4 - viewtopic.php?f=19&t=87464 General discussion - viewtopic.php?f=14&t=99428 Chineese Chineese MK2 Jetta Dash - viewtopic.php?f=17&t=100474 Edited May 2, 2011 by davidwort Quote Share this post Link to post Share on other sites
easypops 8 Posted January 17, 2011 Looks like you forgot this one :D http://wiki.the-corrado.net/late_heater ... epair.html Quote Share this post Link to post Share on other sites
nrc 0 Posted May 2, 2011 Golf MkIII controls are fairly common at autojumbles (VW jumbles anyway!) and scrappies for around £5, and all of the parts are interchangeable with Corrado controls. Quote Share this post Link to post Share on other sites
Tristan H 10 Posted December 26, 2011 anyone know which black cable goes where? took mine out and not sure if they were correctly fitted? And how do get the flap control lower lever up? It seems to be not moving while I rotate the knob . Quote Share this post Link to post Share on other sites
themainliner 10 Posted December 5, 2012 (edited) This is exactly what I was looking but sadly only the link easypops posted works...can anyone provide working ones for VR6Pete's 3 above? Ta. Edited December 5, 2012 by themainliner Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted December 8, 2012 (edited) Which parts of the Mk3 controls do you need? Just the control panel? Do the Bowden cables just match straight up? Edited December 9, 2012 by Anton Sobriquet Quote Share this post Link to post Share on other sites
themainliner 10 Posted December 10, 2012 Anton if you're answering Tristan H I should check the date of his post. Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted December 10, 2012 Anton if you're answering Tristan H I should check the date of his post. No, nothing to do with Tristan H. It was nrc's earlier post that Mk3 controls are interchangeable with Corrado ones. My control panel vent control has broken (I think) and I'm looking for a quick fix. Just wanted to know if the control panel from a Mk 3 is a straight swap, like the Passat one. Quote Share this post Link to post Share on other sites
fonzooorooo 10 Posted April 20, 2013 Just repaired mine with a bit of ingenious plastic welding (direction dial) where the pivot housing for the "underneath" arm had broken, and the cam snail had broken on the underside of the gear. ... Anyway, I had some spares off a 6n polo ('94 - '99) which are tantalisingly close looking, but 1 of the cams is "backwards", so are NOT interchangeable! Just thought I'd flag this up, as scrapyards are full of them at the moment! ---------- Post added at 9:05 AM ---------- Previous post was at 9:01 AM ---------- Just repaired mine with a bit of ingenious plastic welding (direction dial) where the pivot housing for the "underneath" arm had broken, and the cam snail had broken on the underside of the gear. ... Anyway, I had some spares off a 6n polo ('94 - '99) which are tantalisingly close looking, but 1 of the cams is "backwards", so are NOT interchangeable! Just thought I'd flag this up, as scrapyards are full of them at the moment! Quote Share this post Link to post Share on other sites
lard44 0 Posted April 26, 2013 So it's either a Passat heater control, or find a ton for a replacement Corrado panel then? eBay has a few 'Rado ones for strong money, don't see ANY Passat ones on there tho...sadly this is a job I'm going to have to tackle sooner or later... Quote Share this post Link to post Share on other sites
fonzooorooo 10 Posted April 26, 2013 From what's already been said, it looks like a set of mk3 golf ones'd be worth investigating. B3 and B4 passats are getting a bit rare in breakers yards these days. Always worth whipping yours out and investigating the actual fault though, as a bit of creative bodging might sort it! Quote Share this post Link to post Share on other sites
holeinmk1 0 Posted May 18, 2013 sadly when i bought mine it was knackered anyway, does'nt work on any setting cables very very stiff so will be paying the local scrapyard a visit soon lol Quote Share this post Link to post Share on other sites
P3rks 11 Posted May 18, 2013 MK3 golf ones do NOT work. They are very close, but the mechs are backwards and not interchangeable. Plastic welding or liquid metal putty is the way forward. Quote Share this post Link to post Share on other sites
holeinmk1 0 Posted May 18, 2013 Thanks for clearing that one could have been an interesting mistake lol. Quote Share this post Link to post Share on other sites
geoffersmaher 10 Posted August 13, 2013 Where has the chinese Chinese jetta dash link gone? Was it an updated look? Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted August 14, 2013 Where has the chinese Chinese jetta dash link gone? Was it an updated look? The Chinese Jetta dash is LHD with the heater controls the other way round:- [ATTACH=CONFIG]75312[/ATTACH] [ATTACH=CONFIG]75313[/ATTACH] Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted August 14, 2013 Does anyone know how to get the illumination working again? Mine have been out for months!! Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 17, 2013 Does anyone have any knackered controls? I'm after the far left cog, the one where there are 2 Bowden cables going to it... Many thanks. Pete Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 17, 2013 Mmm wonder if I could get the gear reproduced in billet alloy? Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 18, 2013 Does the travel seem normal on this guys? Trying determine why the second set of heater controls have given up again... Seems to go really stiff once everything is connected up, but all appears to move freely when disconnected from the controls? Quote Share this post Link to post Share on other sites
owen g60 10 Posted August 19, 2013 I have the exact same issue. New cables didn't solve it for me. I suspect its the heater box becoming stiff. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 19, 2013 My flaps (excuse the pun) all move with ease with the cables disconnected. It's really weird. The cables also move easily also when disconnected from everything. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 28, 2013 Fixed! After replacing the far left gear as it broke with a spare one I had. Once it all went back together the nob didn't go all the way to the window position, looking at the mechanism, the lever was hitting the plastic before the flap actually closed / open. What I had noticed is that the gear the big gear on the lever the Bowden cable attached too had jumped 3 teeth, which when trying to move the knob more than it was able to travel actually broke the weakest point, the gear in the controls. Using a screw driver to lever the gear on the heater box was able to jump it 3 teeth so if all now lines up and everything now moves really freely and without effort. It's worth checking your gears on the heater box to check its not jumped any teeth, this is the one the lower arm in the heater controls connects too on the heater box. Quote Share this post Link to post Share on other sites
bully 10 Posted December 5, 2013 hi everyone been away a while.. winter is hear and i need th heater sorting.. so i got no pipes leading from my heater box to my windows, ive got very little heat coming through at all.. What i really want to kno is are all of the corrado heaters so weak like a asthmatic mouse coffing through a straw... or is it my heater motor that has gone.? i also want to upgrade to the later style controls.. or if anyone can help me i would like to upgrade it to the climatronic system, not worried about fitting aircon... just want a nice strong heater, ill happily run some pipe up behind the dash to dimist the wondows and blow some heat in the cab... if anyone has done this or can send me a link showing exactly how u can get this done. please let me know. Quote Share this post Link to post Share on other sites
