robrado974 1 Posted February 15, 2011 as above please , i do need this asap . its the one for the direction control that sits on the metal slider, its grey in colour , anyone got one off a broken set ? many thanks rob . Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 15, 2011 Have one mate, but no idea how to remove it without breaking something. And i guess that same would go for replacing it. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted February 15, 2011 I dont have one i'm afraid as mine also broke, the cause was that one the bowden cables had become very stiff which put an increased load onto the cog... took the offending cable out (demister cable) and it was totally kinked up, hence why it became stiff :) Pete Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 15, 2011 Have one mate, but no idea how to remove it without breaking something. And i guess that same would go for replacing it. i know how to remove it , if you dont wont to have a go , how much for the unit ? regards rob Quote Share this post Link to post Share on other sites
easypops 8 Posted February 15, 2011 I might have one........i'll check when i get home Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 15, 2011 I might have one........i'll check when i get home thanks very much , regards rob Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 15, 2011 Can you explain as I've removed the other two cogs, just this one that i was unsure about. I understand how fragile they are just fancied keeping the rest of it as spares. Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 15, 2011 (edited) Can you explain as I've removed the other two cogs, just this one that i was unsure about. I understand how fragile they are just fancied keeping the rest of it as spares. the bit you turn [the knob thingy] should just come away with a gentle twist from a screwdriver they just snap on and off . so does the piece its attached to ,the black wheel will then be free to take out . the grey one [one i need] will then be free to come out . they are snapped in tight . if you dont fancy doing it , no worries as easypops might have one , thanks rob Edited February 15, 2011 by robrado974 Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 15, 2011 the bit you turn [the knob thingy] should just come away with a gentle twist from a screwdriver they just snap on and off . so does the piece its attached to ,the black wheel will then be free to take out . the grey one [one i need] will then be free to come out . they are snapped in tight . if you dont fancy doing it , no worries as easypops might have one , thanks rob Surprisingly that made sense, broke one of the internal black sections but the grey wheel has come out un-harmed. Can now potentially take an entire heater control to pieces. Quote Share this post Link to post Share on other sites
easypops 8 Posted February 15, 2011 I have one.........the one i removed to give to VR6Pete as described in his thread, which he didn't need/want eventually http://the-corrado.net/showthread.php?52275-Heater-Controls-for-Corrado-VR6/page2 The one i have is black though.......possibly out of a set i took out of a vento.......looks identical to the one VR6Pete describes.......if so i'm happy to post you this one :) Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted February 15, 2011 Yeah I didn't need in the end as the heater controls were fubared beyond repair! Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 15, 2011 I have one.........the one i removed to give to VR6Pete as described in his thread, which he didn't need/want eventually http://the-corrado.net/showthread.php?52275-Heater-Controls-for-Corrado-VR6/page2 The one i have is black though.......possibly out of a set i took out of a vento.......looks identical to the one VR6Pete describes.......if so i'm happy to post you this one :) if you are sure its exactly the same i will take it , we did remove one from a polo last night at the scrappy but the snail like bit goes the opposite way!!. let me know how much , if ok i will pay tonight as i need to fit it on sunday . regards rob Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 15, 2011 Have the grey one if you need it. Quote Share this post Link to post Share on other sites
8vMatt 1 Posted February 15, 2011 Ask for some pics Rob just to be sure of what you need mate. You'd be a bit gutted if it turned up wrong. Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 15, 2011 (edited) Have the grey one if you need it. sorry mate should have replied to you first as you were first to reply . how much and pay pal needed ,will do first thing in the morning , as said i need it for sunday ,just to be sure its the grey one that opperates the direction control regards rob . Edited February 15, 2011 by robrado974 Quote Share this post Link to post Share on other sites
easypops 8 Posted February 15, 2011 It does look the same.........yours for free if you want it :) Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 16, 2011 It does look the same.........yours for free if you want it :) very nice of you mate , will pm addy to you regards rob Quote Share this post Link to post Share on other sites
