cheesy
Advice on 9A 16v Strip down/ build up
I've got a spare 9A engine which i intend to swap over with my current engine
Its already had the tolerances on the oil pump checked,
Heads been cleaned
& inspection of bores via camera
Previous owner of engine has done above, was a raf engineer
Now i intend to change/fit new
Cambelt Kit
KR Cam
Cam chain
Aux Belts
Water Pump
Thermostat
Oil/water Cooler
Injectors Been cleaned
New Sensors
Any thing else i should do/consider or upgrade while its still sat on the stand waiting to go in
take a big end shell out and have a look, easy to replace one by one on a built engine, done it under the car a couple of times :) can't do any harm to replace them.
KR and 9A injectors don't really clean up very well, they actually wear out and it's worth replacing them if you want a smooth and nice idling engine, they're good for about 80-100K but will loose performance after that.
Porting the exhaust and inlet manifolds to the head is worth doing too.
cheers david & kempy
Do you know the cost on the injectors?
I'll look into the porting or can this be done diy?
Worth fitting a 4 branch manifold?
is so which would be best?
definitely don't try and port it yourself; you're likely to do more harm than good trying to do it yourself without a flow bench and knowing whatsor of shape the ports should be adjusted to etc.
the only thing that can sensibly be done at home is gasket matching the ports - that will give you a better response and is easy to do with some patience and a dremel-type tool.
port and polish head, four branch, kr cams, new injectors, all new bearings, id do the rings aswell if the engine is out, re-hone the bores, replace all the gaskets and seals, imo id replace the clutch and all cv joints when putting the new engine in, makes a big differnce. if you need anymore info then check out my members thread..
all of the above plus check out the intermediate shaft bearings, always forgotten about and have seen then disintegrate badly, you cant change them when the engine is in the car either.
its definitely do-able to gasket match, and then remove imperfections and smooth the valve runners, heavy porting best left to the pros though.
yep, it adds up with 4 to change, but worth it when the ones you have are on high mileage, they just don't atomise well, particularly at low revs/delivery when worn
might have to buy one a month lol, Id think a fuel filter would help to
cheers for all the info
Give me a list to look into
what brand of 4 branch is the better to go with??
I rebuilt my 9a with;
New VW bearings (crank and conrod)
New vw crank oil seal
New VW piston rings
Kr head with twin kr exhasut cams
Honed and decked block
All new gaskets
S/S 4 branch
Panel filter
Lightened fly
Then got the fuelling sorted at Stealth and rolling roaded at 170bhp.
Well i built the engine over 6 months buying a few bits at a time and replaced anything else that looked worn as i went. Didnt break the bank though, things like s/s manifolds and kr cams can be picked up for very little. The real gains from my car were from having the fuelling set up properly at stealth. Believe i saw an increase of 25bhp at peak and solid increase across the range.
