fla 9 Posted April 27, 2011 Would there be a significant difference in using the 263 map with 264s? Ideally i would get the proper remap done, but presumably this would be a better map than using the standard ecu with 264 cams? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 27, 2011 your pistons will probably melt from the map being 1 degree out. Quote Share this post Link to post Share on other sites
dukest 0 Posted April 27, 2011 mine is 5 degrees out, what will happen to my pistons? :D Quote Share this post Link to post Share on other sites
Rob_B 0 Posted April 27, 2011 mine is 5 degrees out, what will happen to my pistons? :D they will turn into a black hole and the whole car will be sucked in Quote Share this post Link to post Share on other sites
poll250 0 Posted April 27, 2011 I've been running my car on the standard map with 262 cams for a year with no piston explosion lol so I'd say a 263 map with 264 cams shouldn't provide too much of a problem, although not optimum obviously! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 27, 2011 I've been warned this could happen: Quote Share this post Link to post Share on other sites
