Corradoooh!
Help needed with aux water pump
Hi there,
top site.
I just replaced my Corrado leaky aux water pump. The thing is, now that it's back together, is there any way of testing that it's working. I've tried listening after a run but silence. I just put that down to it having a nice new pump.
Any tips for a newby are much appreciated.
Also my driver window motor has died and am flumoxed as to how i take it off the replace. Is the replacement a sirrocco motor?
Many thanks.
It is the most fun car i've ever owned.
The pump usually runs with the ignition on only and you should still hear a new pump working. Pull the plug off and give it a 12v supply.
It's not loud - but with the ignition on you should hear a gentle hum as the pump works away - testing voltage on the plug is your best bet. I usually run these kind of things off the car as a test before fitting. Mine was making a terrible rattling noise before I replaced it.
Thanks for the tips. I put 12 volts and a gentle tap on it and it whizzed up fine.
Now it's a problem with the window.
If it's not one thing.... It's just another reason to love the car.
