GrahamU 5 Posted January 22, 2012 Looks good....when you say you plugged the engine loom into the fusebox, I presume it was a CE2 QPeng loom or similar? I've gone OEM using an ECU from an AGU. Had it all running in my mk1 before the change of plans and as the mk1 is converted to use a corrado dash and fusebox it all plugs into this car without to much hassle. ---------- Post added at 09:13 PM ---------- Previous post was at 09:10 PM ---------- what are the advantages of a mk4 expansion tank? The top comes of easier Quote Share this post Link to post Share on other sites
odub 0 Posted January 22, 2012 oh, I may not worry too much about that seeing as my tank is new. thanks though Quote Share this post Link to post Share on other sites
GrahamU 5 Posted February 19, 2012 (edited) Havent updated for a while, got engine harness finished and started the engine, need to clean the slam panel, finish the front lighting wiring, put the driveshafts, suspension and brakes on, finish the pipework for the cooler and fit the bumper. so heres some pics Edited January 27 by GrahamU Quote Share this post Link to post Share on other sites
Big Adam 0 Posted February 21, 2012 What is the intercooler from? Quote Share this post Link to post Share on other sites
GrahamU 5 Posted February 21, 2012 What is the intercooler from? Renault Traffic Quote Share this post Link to post Share on other sites
odub 0 Posted February 21, 2012 looks like a descent fit and full width Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 21, 2012 Looking good there mate like the progress :) Quote Share this post Link to post Share on other sites
Big Adam 0 Posted February 24, 2012 Renault Traffic any chopping to make it fit? Quote Share this post Link to post Share on other sites
GrahamU 5 Posted April 10, 2012 (edited) Been a while since I updated this and it looks like not alot of progress but it not far of being road worthy now. Brakes fitted still need to bleed them as I sheered of a bleed nipple, grrr Got the front mostly back together Just needs the spoiler fitting and of corse the bonnet spraying All turbo/intercooler pipes are now fitted to the engine and had a turbo in pipe adaptor made so I can run a 70mm hose from the filter to the maf and to the turbo Got some different wheels for it as well am thinking they will look good in white Now changing the cluster for a late one so the tacho works, just need to change the wiring for the indicators and the low coolent light hopefully it will be back on the ground this weekend so I can get it on the drive and put the Recaros in. Will be good to drive it but then I still have a long list to improve it. Edited January 27 by GrahamU Quote Share this post Link to post Share on other sites
GrahamU 5 Posted April 30, 2012 (edited) Finally got it out of the garage and although a little naughty, I did run it up the road and back to find it only had 5 psi. looks like the lack of psi was down to a faulty maf which showed up as a fault code from the ECU, hopefully it will boost a bit better now Not much left to make it road worthy Edited January 27 by GrahamU Quote Share this post Link to post Share on other sites
Big Adam 0 Posted May 1, 2012 Good effort, cant wait to get mine back on the road Quote Share this post Link to post Share on other sites
GrahamU 5 Posted May 13, 2012 (edited) fitted the interior today, thought I would get away with just a hoover but I think the seats need a vax. Edited January 27 by GrahamU Quote Share this post Link to post Share on other sites
GrahamU 5 Posted July 25, 2012 (edited) Been a while since I updated this and it doesnt seem that I'm that much further forward, just as I think its almost ready to hit the road I find or decide to do something else.. So I got it out of the garage, then decided to have a play with the sunroof and roof lining stripped the old lining and recovered it with a fake alcontara also covered the inside of the sunroof Bought some more goodies the brembo's are from a renault clio 197/megane 225 and were different colours so I got them cheap at £100, the coilovers are a bit knackered (that will teach me to take the word of someone saying they were good. The turbo is a K03s which will get fitted when the engines run in a bit. Fitted my boost gauge and a OBD2 port Fitted an electronic tailgate release using a passat boot lock solonoid and then fitted a smooth rear plate mount I'm currently waiting for a guy at work to draw up and FEA some caliper brackets but while I wait I decided to fab up some of my own They seem to fit ok I've now painted the calipers and put some new stickers on Then while this has been going on I've also been smoothing the front bumper got it filled now and just want to be happy with the fiinish before spraying it Today I had a go at the dent in the wing Before After Thats it for now Edited January 27 by GrahamU Quote Share this post Link to post Share on other sites
GrahamU 5 Posted August 2, 2012 (edited) Put a couple of covers over the engine and rad so it looks a bit neater And I finished the bumper so had a go at spraying it, Hasn't come out to bad, got a couple of flys stuck in it though 😞 But it is on now and will do till I can improve my spraying or get the whole car sprayed Just need to fit my LEDs in the headlights for indicators, re-bleed the brakes, tidy a couple of filled areas of bodywork and put the carpet back down in the passenger side and its MOT time Edited January 27 by GrahamU Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted August 2, 2012 Those coilovers don't look too bad mate, just need a clean. The cars looking good though, I like the smoothed bumper! Would be interested in a bit more detail about the boot popper as well. Quote Share this post Link to post Share on other sites
GrahamU 5 Posted August 2, 2012 I'll get some pics of the boot popper at the weekend but for now have a look at this http://forums.vwvortex.com/showthread.php?4783327-MK3-Hatch-Popper-DIY-enjoy! I deleted my rear wiper so I used the supply from that for the solonoid, its also a switched supply only powered with ign which is what I wanted Quote Share this post Link to post Share on other sites
GrahamU 5 Posted August 16, 2012 (edited) MOT Passed Still need to tidy some paint up Edited January 27 by GrahamU Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted October 27, 2012 Good work! Front bumper looks like a really good job. Quote Share this post Link to post Share on other sites
carrots 1 Posted October 27, 2012 i would love a 20v turbo in mine Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted October 27, 2012 i would love a 20v turbo in mine Me 2 !! Quote Share this post Link to post Share on other sites
Rob_B 0 Posted October 28, 2012 i would love a 20v turbo in mine Do it then, it's never been easier to do than now Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted October 28, 2012 Do it then, it's never been easier to do than now If your a mechanic it is, I wouldn't have a clue where to start lol Quote Share this post Link to post Share on other sites
carrots 1 Posted October 28, 2012 (edited) its knowing what you need and the cost,its the wires that would scare me the most Edited October 28, 2012 by carrots Quote Share this post Link to post Share on other sites
Rob_B 0 Posted October 28, 2012 For anyone that wants to do this conversion, head along to the Qpeng website. The guide on there is fantastic. Although its a daunting task for the inexperienced, it's not impossible. I just go by the thinking of what's the worst that can happen? Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted October 28, 2012 For anyone that wants to do this conversion, head along to the Qpeng website. The guide on there is fantastic. Although its a daunting task for the inexperienced, it's not impossible. I just go by the thinking of what's the worst that can happen? That's true I would like to give it ago don't get me wrong :) Quote Share this post Link to post Share on other sites
