fast x 0 Posted March 22, 2004 Hi guys i just got my corrado vr6 on the m plate and is very good, the only thing is the temperature, is it ok to be in 110? cos i hear this engines run a bit hot. also the fan does cut in but the thing is that the temperature nedlle does not got down or up!!! it stays in 110!!! is this at all ok on this engine. any tips or advise will be most apresiated. thanks boys keep up the good work!!! fast x. 8) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 22, 2004 It sits at 110 when you're at speed on the motorway or in traffic? And are you talking about oil temp or water temp? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 22, 2004 Mine sits at 90 most of the time, climbing to a max of 100 after extended periods of crawling in traffic. 110 sounds high but not unusual for the VR. K Quote Share this post Link to post Share on other sites
fast x 0 Posted March 22, 2004 thanks for the tips guys, :wink: and yes is the water temperature thats going a bit high!!! also yes it stays in the motor way and on trafic is always on 100 or just a bit higher. any more sugestion on what can i do will be most apresiated. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 22, 2004 Yeah, it's a bit high if it's doing that when you're moving, on the motorway. Do the fans cut in while you're driving along? What does the oil temp say on the MFA? Quote Share this post Link to post Share on other sites
vr6storm 0 Posted March 22, 2004 also be advised that the water-temp guage aint the most accurate.....mine reads similar values to what your getting but yet when the temp is checked with VAG-COM its quite a bit lower :roll: Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted March 22, 2004 If the water temp is regularly going over 100 (and staying there on thr motorway), check fot coolant leaks - especially around the thermostat housing on the rhs of the engine when viewed from the front. Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 22, 2004 Its normal for the oil temp to hit 108-110 at times ,especially when youre pushing it. I'm on my second car and the last one did this as well. VW say its one of the 'characteristics' of the VR6 and shouldnt lead to a loss in oil pressure and performance provided the oil is good and regularly changed. Personally I keep an eye on the oil temp especially when driving hard and back off after a while if Ive been keeping the oil too hot - you'll find the temp drops rapidly below 4000rpm. Quote Share this post Link to post Share on other sites
Krazee 0 Posted March 23, 2004 Now that i joined this forum, im going to have to brush up Farenheit to Celcius conversions. I dont know about over there, but here we can get low-temp fan-switches and low-temp thermostats. I got both along with a new radiator, samcos and a coolant flush and im running in the 210-230F range (230-240F when hot or romping on it, 210-215F under normal driving). Before hand, I hit 300F a couple times :shock: I highly recommend getting the two switches as it is cheaper than a oil-cooler. Of course this doesnt achieve the same effect, so call it a pacifier until you can afford an oil cooler. Both of the items should run you about 10-15BPS plus shipping. Another thing that can happen is that our clusters can burn out. This happened to a friend of mine and to my car as well. If I turned the headlights on, the oil temp in the MFA would shoot up to 300F. Turn it off and if came back to 220F. My friend told me to check the plug at the back of the cluster for any scorching, but I procrastinated and now its back to normal. See if that whole headlight thing makes a difference....best to do it while sitting, set the MFA to oil temp then switch on ure headlights and see what happens. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted March 23, 2004 sounds to me like the #1 speed on your fan motor has gone...like they always do. Quote Share this post Link to post Share on other sites
JT 0 Posted March 24, 2004 phatvr6 when you say the 1st speed may have gone whats the score with sorting this out... :?: Quote Share this post Link to post Share on other sites
fast x 0 Posted March 24, 2004 Hey guys thanks for all the replys and help, im thinking to take the vr6 to ET motors in seven sisters, do any of u guys had taken ur cars to have em service there? are they any good? wot the reputation u have? also i keep on driving but the tem still in 110, but then it comes down a litle and the fan does cut in, any more solutions? thanks, fast x. :wink: Quote Share this post Link to post Share on other sites
