jamiehamy 0 Posted February 10, 2012 Hey, Got new pads and discs for the rear of the S4, however the pad doesn't cover the whole of the discs area, about 6mm short. I noticed this with my sisters Polo too but can't remember for the Rado. These are Pagid pads n discs. Is this fairly normal? I know the fronts on the rado cover the whole area of the discs (312 TT's). Anyone else come across this and wondered? Just seems like a waste of disc and that performance would be reduced. Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 10, 2012 Does the old disk have the same width braking surface? or is it the pads that are narrower? I wouldn't have thought it would make a lot of difference on the back, pads are half the size of the fronts anyway and don't need to disperse nearly as much energy. I love the new coated disks though, the ones on the back of my golf and corrado look nearly new after a year each has been on. Quote Share this post Link to post Share on other sites
fendervg 32 Posted February 10, 2012 Where did you manage to get coated discs for the Corrado ? Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 10, 2012 standard brembo replacement disks, think pagid are the same now, depends on the stock I had a set of non-abs rears ordered by mistake for the 8v (4 stud) and they came coated, the ABS ones weren't??? so I just swapped the abs rings over as the disks themselves are identical. all the recent disks I've ordered have come through coated now though, rear 5 studs on the golf were too. Quote Share this post Link to post Share on other sites
