Supercharged Will 10 Posted July 7, 2012 I'm after the studs which hold the rocker cover on a vr6. These are usually on obd1 engines. Let me know, thanks. Chris Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted July 7, 2012 Got mine from dealer. Cost me a few quid. Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted July 8, 2012 A liitle more than a few quid I think. That's why I'm asking here. Quote Share this post Link to post Share on other sites
MattPc 0 Posted July 8, 2012 I will have a look tomorrow, see if I have them still, if not the part numbers are N 014 545 2 (8off) & N 102 771 03 (2 off) should be around 60p each from the dealers. Matt Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted July 8, 2012 Stealer want stupid money, wish it was 60p each. Let me know if you have some. Thanks chris Quote Share this post Link to post Share on other sites
StueyB 0 Posted July 9, 2012 Are you after the threaded studs which sit in the head..? The 10mm nuts which bolt it down or the large torx nuts which hold the plastics down on these studs..? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 9, 2012 I was going to renew mine and the manifold ones until vw gave me the price. Sent from my X10i using Tapatalk 2 Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted July 9, 2012 I'm after the threaded studs which go into the block, then the metal rockcover goes on top and held in place with nuts. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted July 9, 2012 If its for the nuts that fit to the studs just m10 stainless steel with washer will sdo that's what I used on Verity check out the build thread for pics. If for the plastic rocker cover speak to tps as will be cheaper Out of interest how much were they? Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted July 9, 2012 Not after nuts, it's the studs I'm after. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted July 9, 2012 ah i see dude fir the early vr then? Quote Share this post Link to post Share on other sites
StueyB 0 Posted July 9, 2012 How many you need..? Think I've got a spare head kicking about which is likely to have these in. Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted July 9, 2012 After all of them if you have them. Let me know thanks chris Quote Share this post Link to post Share on other sites
Supercharged Will 10 Posted July 24, 2012 Anyone got these? Quote Share this post Link to post Share on other sites
