Langsam
wiring harness for rear lights
Hiya, desperately need the complete wiring harness for the rear lights including original plugs to clip into standard rear light clusters. I only need from the rear seats to the main light clusters.
Cheers
Ok sweet, when would you be able to have it removed?
Thanks
I'll have a look tonight for you.
At the car now and have partially removed the loom but there is no connection at the rear seats, from what I can tell without removing carpets it goes direct to the fusebox. So it's all or nothing unless you want to cut and shut?
Hi it will be the same for me,cut or complete,but i dont want to step on anyone's toes
rod
Sorry I've not got back sooner, I thought it would have to be a cut and shut, I'm not too mithered about.
Here are the pics.
I've removed the loom right up to the fusebox, it also serves the petrol pump, connector block behind the centre console and the OBD interface connector so it's not a straight forward swap. Better to cut and shut.
Let me know if this is what you are looking for.
