Jim Bowen 1 Posted August 11, 2012 Been needing this for a while now, Its the plug that goes onto the rad temp sensor. From a 1995 VR6, i think the pins inside are slightly different. Anyone breaking a car they could cut it off of? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 14, 2012 ttt This is getting a real struggle, not wanting to buy a whole loom :( Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 17, 2012 Still looking if anyone could help. thanks Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 18, 2012 You don't need to buy a whole loom - you can buy the plug housings on their own from VAG, and then swap over the contact pins. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 18, 2012 i tried to ordered the part from VW and it turned out to be a rubber sleeve :lol: Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 19, 2012 That's just your dealer - what part# did you order - is it the plug you're looking for ? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 19, 2012 Yeah the bit of wiring side. Looked at ekta with dealer but only showed that bit. Will have to find number, its just a rubber sleeve. Sent from my X10i using Tapatalk 2 Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 20, 2012 I can see the following for the plug - if you need the wiring you'd need to get that separately (wiring repair kit with pins on the end) and crimp it in. 1H0973204 - 4-pin 1H0959481B - 3 pin up to chassis 50 R 000 001 1H0973203 - 3 pin from chassis # 50 R 000 001 Depends on if you have 4 or 3 pins on the sender. Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 20, 2012 How much wire do you need on the connector? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 20, 2012 :lol: I've just been to VW and ordered what fendervg posted. Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 20, 2012 Shame. I'm at a scrappy with a rado in front of me Quote Share this post Link to post Share on other sites
