nickeboy
Rear beam on VR6 is different to 4 cylinders
After hearing divided opinion on the rear beam with many saying the part numbers are the same on all models i checked it out a VW today.
They are not the same the VR6 (abv) Has its own part number (1HQ 500 051 Q) the other models are 191 500 051 with either J, M, or L at the end for different engine codes.
The VR6 one also mentions 20mm in the remark column which i assume relates to the wider track i hear about.
Not seen them side by side but I imagine the beam is different where the bushes fit as the bushes are different to the 4 cylinder cars
