CazzaVR
Loose Metal Bracket- where does it bolt on?
Just had the gearbox refitted and discovered that the metal bracket that is attached to the fan loom is now unattached. Any ideas where this bolts on?
Cheers!
Runs up the chassis leg, then the bracket I think your talking about bolts to the underside of the slam panel I think
Thanks bud- doesn't sound quite right though... reckon it must be on the gearbox somewhere or on the side of the block. At present it's just flapping about near the stat housing/gearbox cables.
Thanks chaps- now sorted! :) Daren, I owe you a beer next time I see you- fits on with the slave cylinder bolts as you say. The rest of the bracket then holds the loom above the gear cables.
