swampy
Inlet manifold bolt kit vr6 1993 and others
having read many threads on here about people changing the inlet manifold and having trouble with the old bolts i have done my research and can now offer them.
i know these fit the above car, am sure they will also fit many other years .
anyway all of the bolts will be stainless steel so can be polished up to a mirror like finish
in the set you will get
qty four bolts from tb to manifold
qty 9 bolts to connect the two halfs of the manifold
qty 9 bolts to connect the lower part to the cylinder head
22 washers
£10 the set delivered
I might be interested. If only I could get my bloody old ones off.. Already sheared one.
even more reason to buy new ones!
how else are you going to secure the inlet again??
Well, the head came off the bolt. It seems to still be holding.. for now.
but for how long?
you know you will end up with an emergency repair when you need it the least
at least if you have the bolts to replace you can do them at your leisure
hi you both have pms.
if i get payment today i can post tomorrow
many thanks
Just paypaled money over...many thanks.
Ill gladly accept commission for this..
The bolts for connecting manifold to the head (same as ones for connecting upper and lower sections of the inlet) = obsolete..
As are the ones for the coil pack and bad news for me the radiator brackets..
You in a position to acquire some of these???
Hi
If you can tell me the sizes, lengthes and qtys them yep I can almost certainly supply items that will be more than up to the job
Im planning on going to my local scrappy where there is a Corrado and ill get a little collection together of bits that would be good if stainless were available..
So long as the car has what i need and what i think would be beneficial to others ill send them to you...
That's spot on, let me have the bolts you want, the area of the car they are from and the qtys etc and we can sort it
I can't make the brackets though unfortunately
Bolts collected today from the scrappy..
Ill put them in zip lock bags and list the quantity needed and what they are for and you can add them to your sales list..
Ill be able to think of others as well should you wish to expand your empire...
Spot on
You got my address??
Ill expand my lines to as many items as you guys want!!!
