Oldtax 10 Posted November 27, 2012 Oil temp reads 96c - that cant be good, right? any thoughts on causes and remedies? cheers Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 27, 2012 Perfectly normal at normal running temps, can get up to about 108 when shifting along. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 27, 2012 Anything around 100c for oil is perfect, as long as the water temp gauge gets to the half way point (and stays there) in around 10 mins in this weather it's all good! Quote Share this post Link to post Share on other sites
VR6 0 Posted November 27, 2012 What were you expecting it to be? :scratch: Quote Share this post Link to post Share on other sites
Oldtax 10 Posted November 27, 2012 VR6 - you've got it in for me! :?: i didnt expect it to be that hot to be honest - so i thought id check. regrets? iv had a few! thanks chaps, most helpful Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 27, 2012 My G60 hit 140c once... the speedo was reading the same figure at the time, I slowed down a bit after! Quote Share this post Link to post Share on other sites
Stonejag 10 Posted November 27, 2012 I've had up to 142 when the cooling system was suffering (that was shortly before my fans seized solid and caught fire, mind...) Normal for mine is 102-110, up to 120odd if I'm really moving along. Planning to fit an external oil cooler next year which should improve things a little - and take some strain off the coolant system - but 96 is perfectly healthy! Stone Quote Share this post Link to post Share on other sites
Oldtax 10 Posted November 27, 2012 Hilarious! found this on yahoo: Engine oils are commonly based on something like a 500 SN paraffinic base oil, and boiling would start at around 300°C, although autoignition would occur above about 400°C. Flash point will be lower, typically around the 280°C mark, although that will not be relevant unless there is a source of ignition present. so looks like you shoulda kept your foot down Supercharged! Quote Share this post Link to post Share on other sites
VR6 0 Posted November 27, 2012 VR6 - you've got it in for me! :?: Just because you're paranoid, doesn't mean I'm not out to get you :lol: Quote Share this post Link to post Share on other sites
Oldtax 10 Posted November 28, 2012 every reply i have from you is negative. i dont know wot i did to u but you should probably give me ur car by way of apology. :norty: paranoid! HA! ... seriously though - did someone tell you that? i think people have been saying that about me. r u one of those people? did you steal my meds? WHERE R MY MEDS? i think i live near u :onfire: Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted November 28, 2012 every reply i have from you is negative. i dont know wot i did to u but you should probably give me ur car by way of apology. :norty: paranoid! HA! ... seriously though - did someone tell you that? i think people have been saying that about me. r u one of those people? did you steal my meds? WHERE R MY MEDS? i think i live near u :onfire: :lol: Quote Share this post Link to post Share on other sites
VR6 0 Posted November 28, 2012 every reply i have from you is negative. i dont know wot i did to u but you should probably give me ur car by way of apology. :norty: paranoid! HA! ... seriously though - did someone tell you that? i think people have been saying that about me. r u one of those people? did you steal my meds? WHERE R MY MEDS? i think i live near u :onfire: Forum, my alter ego. Alter ego, meet the forum. Quote Share this post Link to post Share on other sites
craigowl 0 Posted November 28, 2012 Oil isn't water. Do you young guys get science at school? (Kidding!) Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted November 28, 2012 The owners manual only says to take it a bit easier if it goes over 140 degrees. Quote Share this post Link to post Share on other sites
Oldtax 10 Posted November 28, 2012 Forum, my alter ego. Alter ego, meet the forum. lol :thumb right: thanks all Quote Share this post Link to post Share on other sites
pbradley98 0 Posted November 28, 2012 Managed 136 on a track day.. That was fun! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted November 28, 2012 I saw 130+ after stelvio pass...... had a little breather after that! 96 is nowt mate :) Quote Share this post Link to post Share on other sites
science 0 Posted November 28, 2012 I knew a guy who ran his vr6 up to 160. Engine did not survive. Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 28, 2012 My golf3 got to 160, which is actually the upper limit of the oil temp sensor. The engine didn't survive on that either. Was on the A38 at the time, and my water temp shot up. I'd replaced the rad about a month before, and had only done town driving until then so thought it may be an air lock. Topped it up with water, waited a little while for it to cool, then went on my merry way again. A couple of miles down the road, it did the same. I didn't think to check the oil temp for some stupid reason the first time, but I checked it this time, and it was there! After shutting down, and topping up again once oil temps came right down, it wouldn't start. Crank sensor insulation had cracked away. Turned out the oil cooler had died, and HG had also given way. New lump was only £85 delivered though, and had less milage! :lol: Quote Share this post Link to post Share on other sites
Jim 2 Posted November 29, 2012 I saw about 128 when I took my 16v out on the track once and nothing blew up thankfully... :) Quote Share this post Link to post Share on other sites
fendervg 33 Posted November 29, 2012 Don't complain, 96 is good. A VR will be anything between 88 and 112, with most sitting around 100, my average is 104. Quote Share this post Link to post Share on other sites
pascalsmate 10 Posted December 2, 2012 Ive had my vr at 114 on track but usuall gets to 106 when on song. Quote Share this post Link to post Share on other sites
