Corradochris16v
G60 exhaust on a 16v
tail-box is basically the same, genuine vag ones have slightly different baffles, but nothing that will cause a problem, the 'suitcase box' should fit the same too, but the front box (straight pipe with silencer-looking surround cylinder) is different as it has to mate up to the cat on a G60 or the different downpipe on a non0cat G60 to the 16v.
You also need to make sure it's an early 'hook-type' system and not the later bar hangers.
