edd
plastic window runners from top of door cards - now with photo
As kind of explained above I need the plastic window runners for each side (mine have cracked), these are the plastic bits that the top of the door card fits under/into and seals up against the window when it is closed.
Ideally need postage to Malvern worcs, and they need to be unmarked.
Edd
Edited by edd
addede photo
I'm pretty sure I have a pair mate. I will dig them out in the morning and check the condition for you.
Right edd. I've just read your post again and I'm unsure if these are the bits your after, or the actual top trim that attaches to the door card. These are what I have:
Let me know if I'm barking up the wrong tree.
Cheers bud.
http://www.jimellisvwparts.com/showAssembly.aspx?ukey_assembly=737722&ukey_product=5269386
Its part 17 if you look at this link
---------- Post added at 8:32 PM ---------- Previous post was at 8:27 PM ----------
can't work out if those bits are the ones or not, think these may be 32 or 33 from this link
http://www.jimellisvwparts.com/showAssembly.aspx?ukey_assembly=744097&ukey_make=1066&ukey_model=15552&ukey_category=21727
Think these are the bottom parts that dumptyboy has and I would presume you are after the top part of it.
Cheers bud.
If these are not what Ed is after I may have them off you humpty. Mine are perished to hell lol. These are the ones at the bottom of the door on the outside are they not?
Are these what you want? The hard plastic trim that the doorcard slots into? If so I have these, apart from a couple of scratches at the very end where it sits under the mirror trim, which are not visible once fitted, they are unmarked and no cracks.
£20 posted for the pair?
Edited by chaos3oe
