krishen 2 Posted March 24, 2013 Need a new battery as it needs a boost to start the VR if i leave it for a few days. I remember someone saying VARTA 77AH is the way to go. But all i can find is this one. Can someone confirm if this is as "good" or which VARTA (or any other brand) you'd recommend. http://www.battery2u.co.uk/productsearch.aspx Thanks Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 24, 2013 Bosch aquivalent is a good battery as well , which i have Quote Share this post Link to post Share on other sites
Jim 2 Posted March 24, 2013 I have a Bosch Silver 62AH I think which was £65 from CostCo and comes with a 5 year warranty. Never has any issues cranking the VR even after a few weeks left standing. Quote Share this post Link to post Share on other sites
MattPc 0 Posted March 24, 2013 I also have the Bosch silver battery, still going well after 3 years with no issues. got mine from halfords on trade. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted March 24, 2013 While this threads fresh sorry for being off topic but for what reason would domeone fit a diesel battery on a vr ? Are they more powerfull and would it cause any damage over a long period of time ? Quote Share this post Link to post Share on other sites
MattPc 0 Posted March 24, 2013 You would want to fit a larger battery than the standard 062 if you have a larger than normal current draw, eg. if you were running more electrical accessories. Diesel batteries generally more 'powerfull' as they have a greater power density than the standard 062 VR battery. the only harm that could occur is if you have a greater current draw on the battery than the alternator could supply, possibly causing some circuits to run in a de-rated mode. Matt Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted March 24, 2013 Cheers bud only reason i ask is thats what mine has on it , i only noticed when changing the rad over a few weeks ago when i wipped the battery off the car , i thought it was a bit odd thats all Quote Share this post Link to post Share on other sites
krishen 2 Posted March 25, 2013 Ok not sure if I'm 'researching' this battery business too much but how do you tell which battery is more powerful/better? As in what numbers should I be looking at? To me they all seem the same except for the number of years guarentee they have. Quote Share this post Link to post Share on other sites
Billzeebub 1 Posted March 25, 2013 Another vote for Bosch Silver Quote Share this post Link to post Share on other sites
tonytiger 0 Posted March 25, 2013 Ok not sure if I'm 'researching' this battery business too much but how do you tell which battery is more powerful/better? As in what numbers should I be looking at? To me they all seem the same except for the number of years guarentee they have. You need to look at the Ah and the CCA rating. You'll often find 2 apparently equivalent batteries with the same Ah rating have different CCA - higher is better. And as almost everybody else has said, I'd go for Bosch Silver (S5) or maybe the S4 range if it's significantly cheaper. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted March 25, 2013 Need a new battery as it needs a boost to start the VR if i leave it for a few days. I remember someone saying VARTA 77AH is the way to go. But all i can find is this one. Can someone confirm if this is as "good" or which VARTA (or any other brand) you'd recommend. http://www.battery2u.co.uk/productsearch.aspx Thanks I bought a bosch S4 from eurocarparts for £52 ish Quote Share this post Link to post Share on other sites
VWVW 1 Posted March 25, 2013 I bought a bosch S4 from eurocarparts for £52 ish Need a new battery as it needs a boost to start the VR if i leave it for a few days. I remember someone saying VARTA 77AH is the way to go. But all i can find is this one. Can someone confirm if this is as "good" or which VARTA (or any other brand) you'd recommend. http://www.battery2u.co.uk/productsearch.aspx Thanks You will be fine with the Varta D15 on that web page Thats the one I have its 63 AH. Iam sure its a bosch equivalent of their S5 range. Quote Share this post Link to post Share on other sites
krishen 2 Posted March 30, 2013 Ok i ended up buying the Bosch S5 silver battery. Was going to get the Varta as it seemed to be quite a bit cheaper (£58) but then saw ECP have a decent sale so managed to pick up the Bosch S5 silver for £73. A little bit more that the Varta but at least i got to sort it today instead of having to wait till next week. Very impressed (although probably would be with any battery as mine was on its last legs). Anyone know where you dispose of the old battery? Quote Share this post Link to post Share on other sites
tonytiger 0 Posted March 31, 2013 Good choice of battery I think. Battery disposal - you should be able to take it to a household waste recycling centre, a scrapyard (who may even give cash for it) or possibly to ecp as they may be obliged to accept. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 31, 2013 But before you replace the battery, make sure that you don't have a dodgy circuit somewhere that's draining it .. otherwise you'll knacker your new one as well. Quote Share this post Link to post Share on other sites
krishen 2 Posted March 31, 2013 But before you replace the battery, make sure that you don't have a dodgy circuit somewhere that's draining it .. otherwise you'll knacker your new one as well. How can i check that? Just running a voltmeter on the battery? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 31, 2013 You need to put an ammeter in circuit with the battery and measure the amount of current that the car is drawing when everything is turned off. Many multimeters will have a "10A" mode that would do ok. Just make sure the engine is cold and the fans aren't going to come on or anything like that. Quote Share this post Link to post Share on other sites
