Dox 23 Posted April 22, 2013 I've agreed to buy Hennys G60 rolling shell minus the wheels, I have 5 sets of 5 x 100 wheels and would prefer to swap and change as and when needed so I'd like to go 5 stud. Can I just obtain a pair of drive flanges and press them in or do I need Corrado VR6 (MK3 golf gti?) hubs complete? The car is an early H plate with narrow body I've used search facillity, looked in wiki etc but can't find an answer Hennys old build thread http://the-corrado.net/showthread.php?12211-Henny-s-G60 Quote Share this post Link to post Share on other sites
GrahamU 6 Posted April 22, 2013 I stripped a 4 and a 5 stud hub the other day, they measured the same so the 5 studhub will fit into the g60 bearing. The difference I could see was the spline for the CV. If the spline on a g60 driveshaft is the same as a VR driveshaft then I dont see the need for swapping the whole lot. The disc will have a different offset but many people re-drill discs for the right stud pattern There may be something I'm missing so someone may correct me. For the rears its just a case of changing the rear discs for 5 stud Quote Share this post Link to post Share on other sites
Dox 23 Posted April 22, 2013 I stripped a 4 and a 5 stud hub the other day, they measured the same so the 5 studhub will fit into the g60 bearing. The difference I could see was the spline for the CV. If the spline on a g60 driveshaft is the same as a VR driveshaft then I dont see the need for swapping the whole lot. The disc will have a different offset but many people re-drill discs for the right stud pattern There may be something I'm missing so someone may correct me. For the rears its just a case of changing the rear discs for 5 stud I've got 312s for the front brakes, the car is to be built on a very tight budget using parts I already have for the most part. Thanks for the reply Quote Share this post Link to post Share on other sites
clumpy1 11 Posted April 22, 2013 Dox have a look at stoney's build thread (my car now) it was a G60 but i have 5stud his thread may shed some light you might be better looking at baron's thread as he has a link to stoney's. Quote Share this post Link to post Share on other sites
dragon green 5 Posted April 22, 2013 Eurospec sell hubs to convert from four stud to five Quote Share this post Link to post Share on other sites
Dox 23 Posted April 22, 2013 Dox have a look at stoney's build thread (my car now) it was a G60 but i have 5stud his thread may shed some light you might be better looking at baron's thread as he has a link to stoney's. http://the-corrado.net/showthread.php?24656-G60SC_Stoneys-C!-Nearly-there!/page23 It took me a while to find stoneys thread, but it appears he fitted 5 x 100 flanges to g60 hubs? Thanks all for the replys :) Quote Share this post Link to post Share on other sites
