B5VWC
Black VR6 - Rotrex - Mapping Update on Pg 20
Cheers mate same as - you got good numbers on sunday..
Good to see another rotrex setup theyre not bad little chargers - what you planning next? cams.
Yep 263's, some form of charge cooler and then tiny pulley :D
yeah the 263s should make a good difference we did a before-after just to see what they can do
what pulley you got on yours now, mine is 85mm which saw 17psi... 350-360hp was the target :lol:
Im running an 80mm pulley on mine but mine is only the 74 as apposed to your mahoosive 94 so mine only makes 7 psi. I will most likely go for a 70mm pulley, not sure what it will give though, probs about 10psi perhaps?
Need some cooling first, cant afford a charge cooler setup at the mo as driving the car round europe end of may so im thinking just to get some form of cooling i will just got for aquamist to start with.
Seriously good effort.. must be awesome. Whats it like through the front wheels? Bet its ok actually because it doesn't give a sudden surge of power like a turbo might give?
Well done..!
Ben
Seen this car too - but didn't get to meet you on sunday for some reason! lovely car - was hoping it was going to the rollers though! :(
yeah you no point having chargecooler till you want the big numbers but then you need to strengthen engine/lower comp too and it all starts getting serious ... so up to 300hp should be good
Well done..!
Ben
thanks matey its not too bad the peloquin diff helps and midrange isnt mental but still strong then after 5k/8psi it shifts hard theres only so much the gearbox/wheels can cope with prefer to get the power down and not waste it
thanks mate - didnt run it as it was only on rollers a week before - at the end i did ask vince to run mine for free but he told me to fuck off :D
Likewise.. Bills cars lovely.. really love that car.. yrs is just nuts!!
Bally - and your ride too respect for a daily driver but looking better and better - you got any engine plans then???
Thanks bro.. yes engine will get just as much attention as the rest of the car :D
thanks mate - didnt run it as it was only on rollers a week before - at the end i did ask vince to run mine for free but he told me to **** off :D
LOL!!
Update after about 1000 miles and **** loads of V Power
Had a few issues with radiator & bonnet Cable but all sorted now
Did run lean at idle for a while so really rough idle, replaced damaged maf sensor and added mesh to housing
Replaced VDO gauges
They are Digital Dakota Gauges
Edited by B5VWC
LOST LINKS
Check out video its all about getting the power down
Edited by B5VWC
LOST LINKS
nice updates mate, really like what youve done with the rado looks mean and moody and its got serious grunt to match by the look of them videos.
are you at the ricoh meet tomorrow? would love to check it out in the metal, I missed out when i bought the speedlines off you last yr!!
anyway i think youve modded it enough now, so get out and enjoy it 8)
Alrite mate should be at ricoh 2moro yeah see you there
Been enjoying it for a few months now spend most days at the Shell garage too :)
Looking good mate, you got the Exhaust on :)
Not yet mate its at the garage getting the second lambda welded in for the wideband prob fit end of week
Hows yours going cant wait to see it pop over coventry sometime should only take you half n hour to get here :D
That Exhaust will free up bit more BHP
Going very well mate, once you got this sort of power it starts to get mental :grin:
Needs some bigger brakes, everything comes up so quick :shocked!:
I was looking at this setup it uses 330mm APRacing calipers
MJMAUTOHAUS
$ Rate is good shipped to UK comes to £930 but add vat/customs, still AP are best, also will they fit behind your rims
MJMAUTOHAUS
Thanks for the link mate, will be doing brakes next for sure
AP Racing + Pagid RS15 :notworthy:
You will p1ss yourself laughing when you stand on them.... just make sure no one's behind you!
Update.
Needed to sort a few things like tired valve springs (7500 limiter), better exhaust and dodgy alternator but ended up doing all this…
Slowly did all the work over the last few months myself as there was no rush and saved some cash
It’s now back up and running checked everything over and its all good so happy I gave it a go
Will get back to you with Dyno Results soon
Edited by B5VWC
LOST LINKS
Saw it on the rollers yesterday whilst Doctor Vince was doing his mapping magic.
It's coming along nicely and is now the most powerful car on the forum I think :wink:
Yeah it made over 400 before this, but not too bothered about the peak power just happy its turned out well, learnt alot good experience
Should flow alot better now im going there 2moro to see how its done
