Sean_Jaymo
Bit of a garage clear out - VR6 stuff mainly
I'm having a bit of a garage clear out and looking to make some space!
Items are located in Lincolnshire, LN4 Postcode. Collection is preferred but the smaller stuff can be posted at cost if needed. I'm open to the idea of offers but don't take the mickey and remember that due to the unique way in which the Royal Mail rip people off, I can't post out everything for £5!
Corrado door cards - Good condition. £30
Corrado rear humped bench - Good condition, carpeted back of seats in very good condition! £40
Passenger Seat - Very good condition - The drivers seat is available for Free if you want it, it's pretty well worn though! If it doesn't go, I'll turn it into an office chair at some point! - SOLDPower steering cooling pipe - £5
VR6 Cross member with engine mount - £SOLD
VR6 rear engine mount - £15
VR6 Girling rear brake calipers - Fully working £30
VR6 Lucas rear brake calipers - untested and painted red by a previous owner! They look to be in good nick to be fair but won't promise anything - £15
VR6 Front Brake Calipers and carriers - Fully Working £45
VR6 Front hub assembly with ABS Sensor and ball joint - £50 for the pair
VR6 Cat and lambda sensor - Working when removed - £30
VR6 Wishbones - £25 the pair
VR6 Flywheel and pressure plate - £30
Blasted and Powder coated 280mm brake shields - SOLD
Blasted and Powder coated 280mm brake carriers and Blasted and primer coated bare 280mm calipers (no pistons, seals, bleed nipples etc) - £40
Brake cooling wings - £15 - Apparently these are "eBay RARE!!!"
Edited by Sean_Jaymo
They would, but they are for 280mm brakes so would be a bit small. It's the reason I didn't fit them to mine, I decided to go for 288's instead of 280's.
Saturday 20th at Castle Combe, Chippenham nr Bristol. I'm after the passenger seat, specifically the bolsters to repair my drivers side. Your a bit far or I would have picked it up, and its probably too much hassle tearing the seat down to pack up and post the bolsters alone for the price. No worries though mate, I'll keep an eye out! :thumbleft:
Ahhh, The Autometrix track day! I've done that a few times when I lived in Oxfordshire!
I've had a few messages on other forums regarding the front seats as a pair so unfortunately it would be too much on this occasion. Good luck finding something tho! It must be one of the final touches to getting yours good again after previous owners did their best at ruining her!
That's fine mate, thanks anyway. I've got a long way to go yet until mines finished though! Mechanicals are pretty much done now. A couple of electrical gremlins to sort out, then its onto interior before exterior next year. Good luck with the rest of your sale mate, you shouldn't have too much trouble shifting that little lot!
Give me a moment, ill try and get a picture up!
---------- Post added at 11:40 AM ---------- Previous post was at 11:12 AM ----------
Lucky you asked me! I was sold them a while back as fitting onto 280mm calipers. Looking at the part numbers, my versions are for 239mm calipers! Bugger! Teach me not to research before buy or selling!
Luckily I never sold these to anyone on here, that would have been embarrassing!
Part numbers for anyone concerned are 1H0 615 194A/B
I'm sure someone with a bit of something about them could make them fit fairly easily, if they wanted to!
Sorry about that!
Not the best picture, but these are what they look like and where they bolt on.
They bolt onto the back of the caliper with 2x M8 x 10 bolts.
If these don't sell, i'll just try and fab them onto the 288 calipers and see what's what!
Hi matey do you still have the vr calipers and carriers? Showing my ignorance here I know with my old golf vr there was 2 types of brake manufacturers fitted depending on the age of the car would these fit my 95 vr do you know? Pete
All rado vr6's had 280mm brakes and they are fully interchangeable.
The Golfs had 288 brakes fitted to the later run out cars.
If you want these for a rado, they will definitely fit!
I have 2 sets, 1 set is a bit grubby but work perfectly well and are ready to bolt straight on.
The other set has been blasted and primered but needs pistons and seals and some paint to be as new when you fit them.
