Danhowyn 10 Posted July 17, 2013 Hi there, new to the forum, just picked up a g60 and it's a great car, like it a lot. I have been given a golf intercooler but no pipes! Does anyone no what I will need to get it to fit? Thanks dan Quote Share this post Link to post Share on other sites
owen g60 10 Posted July 17, 2013 Your best bet would be to search German eBay for a supplier. Or I believe max-rpm.de do the kits for about £150 to plumb them in Quote Share this post Link to post Share on other sites
Henny 0 Posted July 18, 2013 BAR-TEK do a full kit of the pipes, including the U-bend you need to go from the charger to the intercooler... This one -> http://www.bar-tek-tuning.com/lshop,showdetail,21250,en,1374144736-21293,tuning.1080551703,2160009,195,Tshowrub--tuning.1080551703,.htm And this one -> http://www.bar-tek-tuning.com/lshop,showdetail,21250,en,1374144736-21293,tuning.1080551703,2160087,196,Tshowrub--tuning.1080551703,.htm Just under €600 all in, which isn't cheap, but it's beautifully made stuff and spot on fit-wise... :) Quote Share this post Link to post Share on other sites
Danhowyn 10 Posted July 19, 2013 Okay thanks for that info guys! That is quite pricey isn't it! Would you recommend a performance air intake aswell? Quote Share this post Link to post Share on other sites
Henny 0 Posted July 19, 2013 nope, stick with the paper filter with a G60... cotton or (even worse!) foam ones let too many small particles through which turn into a grinding paste within the charger causing excessive wear and eventual failure of the charger... :( Don't forget, those parts on Bar-Tek are brand new uprated parts.... second hand ones pop up on ebay and on quite a few forums regularly, but at least you can see in their pics exactly which parts you need to get hold of! ;) Quote Share this post Link to post Share on other sites
